best cure for mangled lower control arm bolt holes - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2013, 10:35 AM
if you beat my boat, well race
im workin on my buddys 57 chevy belair.
doing a full caltek suspension package.
on the drivers side lower control arm, one of the bolts on the stock control arm, almost pulled thru the frame.
i didnt notice, until i put the new tubular arm on, and theres a significant gap inbetween the frame and control arm, the bolt (new 7/16-fine, grade 8) would not pull it together. i tried tightening it but to only de-thread the bolt. same with a 7/16 corse thread bolt.
my oxy is gone so heat is out of the question for a sunday.
i could cut it out, or grinding it, but this will weaken the frame.
what would you do?????
thanks guys!
Old 04-08-2013, 08:36 AM
I can't see it but obviously welding it is what SHOULD be done, repairing it properly. There are some gray areas that I don't want to even suggest.
If you posted some photos maybe it would be a lot clearer and something could be done but right now, broken frame, control arm mount broken out? Weld it properly.
Old 04-11-2013, 09:47 PM
the bolt didnt pull through all the way, i got off my behind, filled the tanks, heated it up,bent it back, and put an extra thick washer on it and welded it up.
shes golden now
Old 04-12-2013, 07:33 AM
Yep, sometimes you just have to bust out the big boys.
globlewest lower control arm racecartom Suspension - Brakes - Steering 0 03-01-2012 09:12 PM
lower control arm bolts helrazr3 Suspension - Brakes - Steering 3 07-09-2007 07:10 PM
Lower Control Arm 71 c-10 Suspension - Brakes - Steering 2 03-29-2007 12:08 PM
73 vette lower control arm bushings tam5892 Suspension - Brakes - Steering 2 07-25-2006 08:47 PM
Removing Lower Control Arm Shafts 63SS Transmission - Rearend 0 05-09-2006 07:04 AM
