-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   best DA sander to get? (http://www.hotrodders.com/forum/best-da-sander-get-159298.html)
jss 05-30-2009 09:06 AM
hey guys I want to get a nice da 6" palm air sander for my shop any ideas whats a good one? do any have lifetime warrenty?
thanks
Chris Kemp 05-30-2009 10:36 PM
thanks
I my opinion and I will probably catch some flack here, I like the Hutchins model 3500 the best. I have two of them but I only need one. I just bought the second one because I couldn't turn down the price. And speaking of price they are kind of pricey but they are worth it. Hutchins is a great company, been around as long as I can remember and I have never had any problem with any of their tools.
http://www.hutchinsmfg.com/
oldred 05-30-2009 11:32 PM
You asked what's the best DA? That would be the Hutchins but there are some less costly DAs out there that will get the job done just stay away from the Harbor Freight types. If you want the best most reliable DA then check out Hutchins.
JeffB 05-31-2009 12:43 AM
Da
One thing to keep in mind is any air sander will use a lot of air and you might want to post the compressor you are using to help in that choice,constant stopping and starting can be a pain.
jss 05-31-2009 10:22 AM
http://www.chpower.com/webapp/wcs/st...1_10646_10692_
this the one I have should be just fine for most da's
what about brands like DynabradeDYNALOCKE?
http://www.tooldiscounter.com/ItemDi...gle&kw=HUT4500
for hutchins looks like this is the only model for palm style da. is this what u all are talking about?
looks good
milo 05-31-2009 12:58 PM
I have had a few da sanders through the years and wanted to add the smoothest and lightest in my box is a Dynabrade 6 inch. I have oppted not to oil it since new figuring if it dies or locks up it will have been worth not getting oil out the exhaust onto a panel causing a fisheye.
More than ten years of daily use with no tool oil in it at all...
http://www.levineautoparts.com/dy6indasa.html
jss 05-31-2009 01:18 PM
wow good to know. so the vibs are ok pretty smooth to use?
jss 06-01-2009 11:21 AM
I think I decided to go with the dynablade
silver supreme. is 3/16 good spec to get?
deadbodyman 06-01-2009 05:45 PM
"hutchins"the best sander on the planet.but I bought a ingersol rand at Lowes for 100.00 thats pretty darn good,not hutchins good but very good its light too
finish-master 06-06-2009 01:26 AM
that's the same thing i do. i hate it when you add a few drops to many. then when you use it shots all over the place.
jss 06-06-2009 11:11 AM
thanks for the info guys big help
JeffB 06-06-2009 11:40 AM
Da
Use common sense! remove the disc,oil the DA away from your work,run for a minute,wipe it down,reattach the disc and go to work.The best way to screw anything up is to hurry,hurry,hurry :nono: ,take your time and do it right.
jss 06-07-2009 06:21 PM
thats true.. most tools call for 30 sec run time after oiling
1Bad406sbc 08-27-2009 06:06 PM
I would go with a dynabrade, or a hutchins. Both are VERY good sanders.
Jon 08-27-2009 06:35 PM
Added this info into the Sanding wiki article.
