best DA sander to get? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2009, 09:06 AM
jss's Avatar
jss jss is offline
hey guys I want to get a nice da 6" palm air sander for my shop any ideas whats a good one? do any have lifetime warrenty?
thanks
Old 05-30-2009, 10:36 PM
thanks
I my opinion and I will probably catch some flack here, I like the Hutchins model 3500 the best. I have two of them but I only need one. I just bought the second one because I couldn't turn down the price. And speaking of price they are kind of pricey but they are worth it. Hutchins is a great company, been around as long as I can remember and I have never had any problem with any of their tools.
http://www.hutchinsmfg.com/
Old 05-30-2009, 11:32 PM
You asked what's the best DA? That would be the Hutchins but there are some less costly DAs out there that will get the job done just stay away from the Harbor Freight types. If you want the best most reliable DA then check out Hutchins.
Old 05-31-2009, 12:43 AM
JeffB's Avatar
Da
One thing to keep in mind is any air sander will use a lot of air and you might want to post the compressor you are using to help in that choice,constant stopping and starting can be a pain.
Old 05-31-2009, 10:22 AM
jss's Avatar
jss jss is offline
http://www.chpower.com/webapp/wcs/st...1_10646_10692_
this the one I have should be just fine for most da's
what about brands like DynabradeDYNALOCKE?
http://www.tooldiscounter.com/ItemDi...gle&kw=HUT4500
for hutchins looks like this is the only model for palm style da. is this what u all are talking about?
looks good
Old 05-31-2009, 12:58 PM
milo's Avatar
point on positive
I have had a few da sanders through the years and wanted to add the smoothest and lightest in my box is a Dynabrade 6 inch. I have oppted not to oil it since new figuring if it dies or locks up it will have been worth not getting oil out the exhaust onto a panel causing a fisheye.
More than ten years of daily use with no tool oil in it at all...
http://www.levineautoparts.com/dy6indasa.html
Old 05-31-2009, 01:18 PM
jss's Avatar
jss jss is offline
wow good to know. so the vibs are ok pretty smooth to use?
Old 06-01-2009, 11:21 AM
jss's Avatar
jss jss is offline
I think I decided to go with the dynablade
silver supreme. is 3/16 good spec to get?
Old 06-01-2009, 05:45 PM
deadbodyman's Avatar
Wiki Edits: 11
"hutchins"the best sander on the planet.but I bought a ingersol rand at Lowes for 100.00 thats pretty darn good,not hutchins good but very good its light too
Old 06-06-2009, 01:26 AM
that's the same thing i do. i hate it when you add a few drops to many. then when you use it shots all over the place.
Old 06-06-2009, 11:11 AM
jss's Avatar
jss jss is offline
thanks for the info guys big help
Old 06-06-2009, 11:40 AM
JeffB's Avatar
Da
Use common sense! remove the disc,oil the DA away from your work,run for a minute,wipe it down,reattach the disc and go to work.The best way to screw anything up is to hurry,hurry,hurry ,take your time and do it right.
Old 06-07-2009, 06:21 PM
jss's Avatar
jss jss is offline
thats true.. most tools call for 30 sec run time after oiling
Old 08-27-2009, 06:06 PM
1Bad406sbc's Avatar
Crazed and confused
I would go with a dynabrade, or a hutchins. Both are VERY good sanders.
Old 08-27-2009, 06:35 PM
Jon's Avatar
Jon Jon is offline
Hotrodders.com Administrator
Wiki Edits: 7314
Added this info into the Sanding wiki article.
CP870 DA Sander Finaltheorem47 Body - Exterior 8 03-13-2009 06:24 PM
DA sander scratches in rear window rusty428cj Body - Exterior 2 02-15-2005 08:13 AM
Craftsman DA Sander & Sandblaster 70chevy Garage - Tools 10 12-28-2004 10:51 PM
Source of wet-or-dry for DA sander? willys36@aol.com Body - Exterior 3 12-15-2004 07:08 PM
My DA sander broke :( Rubberman2003 Hotrodders' Lounge 10 11-13-2003 12:10 AM
