Best, easiest way to support engine for bellhousing alignment? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2011, 07:17 PM
v8hed's Avatar
AK427
As most engine stands support the engine using the bellhousing bolt holes in the block, they obviously can't be used to support the engine when checking bellhousing alignment. I really don't want to purchase a cradle that I will probably never use again, so is there a cheap, easy way of supporting the engine for the bellhousing check? I was thinking about standing the motor on a wooden pallet (sitting on the oil pan), securing it with ratchet tie-downs, then bolt the bellhousing up and doing the alignment. Is there a better or even easier way?
Alternatively, can these cradles be used with the motor mounted 'backwards' so the bellhousing bolt holes are available?
http://cgi.ebay.com/ebaymotors/1000L...item2561b40a4b
Thanks.
Old 03-05-2011, 07:27 PM
I have put the motor mounts on an engine, and then set the motor mounts on wood blocks. You then can "take up the space" under the oil pan with more wood blocks, at the front or rear of the engine. This will keep most of the engine weight off the oil pan.
Old 03-05-2011, 10:45 PM
SSedan64's Avatar
That type wont work.
This type will>> http://www.speedwaymotors.com/Chevy-...ands,2623.html also easy to make & add Casters. The wood block idea will also.
A few others here>> Anybody used an engine cradle?
Old 03-06-2011, 05:24 AM
v8hed's Avatar
AK427
Thanks. I like the Moto Feet style stands, but there's nowhere to get those in the UK that I'm aware of. They look easy enough to make, but I don't have a welder.
Anyone got any pics of a motor mounted on wood blocks, just so I can visualise it?
Old 03-06-2011, 06:13 AM
bigdog7373's Avatar
Of course it's fast
Put it on an old tire.
Old 03-06-2011, 06:18 AM
poncho62's Avatar
Wiki Edits: 5
Maybe I am going to sound stupid here, but what are you going to do if you find out if your bellhousing is out of alignment? Is there not dowel pins that hold it in position anyways? Dont see the point of the whole exercise.
Ontario Rodders
Old 03-06-2011, 06:29 AM
v8hed's Avatar
AK427
I need a way to support the engine so that I can check the bellhousing alignment. Yes, the bellhousing locates on a pair of dowels. The dowels are available in different offsets to correct any misalignment between the bellhousing and crank centreline.
Old 03-06-2011, 06:31 AM
v8hed's Avatar
AK427
Can't use a tyre as I need to be able to turn the engine on the balancer, so the front of the engine needs to be unhindered and the engine needs to be pretty secure.
Old 03-06-2011, 06:51 AM
LATECH's Avatar
Last journal entry: New Gas Tank
What kind of car has that?
Old 03-06-2011, 07:02 AM
SSedan64's Avatar
They're available for lots of engines. I know Lakewood makes them, .007", .014, .021" offsets.
Example>> http://performanceparts.com/part.php?partID=22081
More here>> http://www.summitracing.com/search/B.../?autoview=sku
Wiki Edits: 27
wood box
I've make a couple wood boxes out of 2 X 8 lumber, double H shaped' 2 short pieces between the longer pieces and screwed upright pieces that meet the oil pan side rails
Engine alignment ssmonty Engine 9 07-22-2008 10:10 PM
engine support beam Mr.NutCase Garage - Tools 5 03-03-2008 09:00 AM
Is bodyfiller problematic over rad support, engine compartment Ripped Body - Exterior 2 05-02-2007 02:32 PM
engine support ideas 85406 Transmission - Rearend 5 09-25-2004 07:37 PM
sbc engine shipping stand/support jdreher General Rodding Tech 3 02-13-2004 06:15 PM
