Best Engine? - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 04-17-2011, 09:30 PM
the 347 will make excellent power in a small package but in my opinion its pushing the stock block geometry to the limit.
i think a more reliable combo would be the 331 sbf stroker you get a way longer skirt on the piston and block bore and really helps stability of the pistons at rpm.
im not sure if you need a reduced base circle cam but the 331 would help reliability in that area also.
and these are the guys to get it from
http://www.dssracing.com/D_S_S_Small...ngines_s/3.htm
350 Crate Engine: Loud humming sound after engine warms up sofa1515 Engine 2 01-11-2010 06:48 PM
Engine Help. Engine Turns over Hard, like siezed yet runs awsome. Merle9069 Engine 3 10-05-2008 06:38 PM
I need engine mount bracket ideas 1930 chevy with 302 boss engine. Riley Engine 3 07-25-2008 07:29 AM
say you have a THOUSAND horsepower engine..... (technical engine question inside) lowROLLERchevy Engine 14 02-24-2007 08:26 AM
strange engine problem with check engine light brian12c Engine 2 07-29-2006 09:55 PM
