-   -   Best engine paint? (http://www.hotrodders.com/forum/best-engine-paint-24216.html)
nomis30 09-24-2003 06:36 PM
Best engine paint?
Looking for a Pontiac type blue paint for the engine block and heads. Do the local auto stores sell block paint and what is the best kind to buy. Also heavy coats or a light coat?
302 Z28 09-24-2003 06:49 PM
I used to use nothing but VHT high heat engine paint. I couldn't find any one day, so I picked up a can of DupliColor engine paint, seems to be as good as VHT IMO.
Vince
Kevin45 09-25-2003 03:42 AM
You can buy engine paint in rattle cans that is factory or you can go to your local jobber and get any color you want for the engine.
Kevin
Weimer 09-25-2003 10:47 AM
I think that the only difference between engine paint and regular paint is the ability to resist gas/oil....not heat like most people think. An engine block does not get that hot...its the exhaust where you would want the high heat paint.
I have seen lots of guys use regular bc/cc that was left over from their car to paint the engine to match.
JMO....
Later,
WEIMER
302 Z28 09-25-2003 11:12 AM
WEIMER is correct, about the high heat, just a selling point. The use of BC/CC is very common anoung street rodders.
Vince
RetroJoe 09-26-2003 05:25 AM
I found my Pontiac paint at my local Kragan store. It was $3 a can and at Summit they wanted $7 for the same paint!
78 monte 09-28-2003 01:18 AM
I like plasticoat I find that it flakes off much more gracefully than the others.
