best engine to put in a s 10 - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-23-2003, 04:36 PM
datsun350's Avatar
Just go smallblock
CHEVY smallblock
  #17 (permalink)
Old 08-23-2003, 10:20 PM
Lightbulb
howziit guy!
JMO, if you anticipate traction problems with a sbc in an S10...install a "small" sbc...namely a 302.
if that's too expensive, just find a sbc 283, sonic test for block integrity, bore out .125", and build "THE GIANT KILLER" of the early 60's..."the 301"!
  #18 (permalink)
Old 06-13-2004, 12:18 PM
Z-BEBAD's Avatar
MY SON IN-LAW AND I ARE ABOUT TO PUT A V-8 IN HIS 94 4X4 EXT. CAB. WE ARE PUTING TOGETHER A 327 C.I. FOR GAS MILAGE & PULLING THE LIKE'S OF A SMALL ATV TRAILER. I USE TO HAVE A 65 VETTE AND GOT GREAT GAS MILAGE WITHA 600 HOLLEY , FIGURE IT CAN'T BE ANY WORSE THAN THE 4.3,PLUS A LOT MORE POWER, I HAVE NEVER SEEN A 350 GET NEAR THE MILAGE AS A 327 DOES.
  #19 (permalink)
Old 06-13-2004, 01:54 PM
my brother dropped in a 350 a few years back into his s10. He isnt much of a mechanice but hes not an idiot either he never had cooling problems and this was in Midland TX, the center of the sun!
  #20 (permalink)
Old 06-13-2004, 02:42 PM
77z's Avatar
77z 77z is offline
Go big or go home
1987 3.8 granny motor 200r combos are sick too in a s10 and get something my toy does not gas milage Little work to make a s10 scare the kids and laugh at most imports but hey since its so hard to find boneyard grandnationals now any small block chev with a mild cam intake carb combo will make that little truck move along hapily. The hardest thing is to get the suspension working good enough so they hook up . Side note 4cyl 5 gear s10s have 410 gears btw
Mike
77 Z28 496 9 inch
10.23 @ 129
  #21 (permalink)
Old 06-13-2004, 03:41 PM
Turbonoma's Avatar
"Gettin High On Boost"
Last journal entry: More setbacks
Well I myself went with what came in my Sonoma. I decided to
build a turbo powered 4.3 V6. I did get a blueprinted marine
engine and a set of ported heads with over sized valves. Got
forged pistons and rods. Comp hydraulic roller cam and roller
rockers. Check out my project journal. PEACE>Tony
  #22 (permalink)
Old 06-13-2004, 06:15 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
What a bunch of responses... OBVIOUSLY the biggest, most powerful motor you can put in there will make it go the fastest. I'm assuming that's what you mean by "best."
K
  #23 (permalink)
Old 06-13-2004, 06:45 PM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
The motor is probably in the truck by now, this post is almost a year old.
  #24 (permalink)
Old 06-13-2004, 09:44 PM
Z-BEBAD's Avatar
YEAH, THE MOTOR PROBLY IS IN BY NOW.WHAT'S WRONG WITH ADDING MORE INFO TO AN OLD POST ? SOME OF US ARE BUILDING SIMULAR PROJECTS AT THE MOMENT AND LIKE TO HEAR MORE ON THE SAME TOPIC. THATS WHY THE OLD POST ARE THERE
FOR US ALL TO READ UP ON, ADD TO, AND MABEY LEARN A THING OR TWO.
  #25 (permalink)
Old 10-07-2004, 12:28 AM
1tonkatoy's Avatar
New Member
i agree deadman, i have been gathering info and parts for 4 months. now that the
2.8 is out and the 350 is going in. this is really going to be fun!
  #26 (permalink)
Old 10-07-2004, 05:59 AM
brainsboy's Avatar
brains
I would go for the big block. Look at my gallery. I just put a 408windsor stroker into my 87 suzuki samurai, If I can do that you should have no problem fitting a bigblock in your s-10.
Ben
  #27 (permalink)
Old 10-07-2004, 02:04 PM
Mopar_Truck's Avatar
New Member
Last journal entry: Dodge mania
I would maybe consider a 327 I may be a dodge guy but that is a really good high rev motor. Or maybe perhaps a 305 tune barrol FI engine. That could be an interesting combo I know they went pritty good in the camaro's. Also my friend has a 85 s10 with a 350 out of a 96 truck it motors not bad, and gets pritty good gas milage ( are you planning to lower it? because he had problems with the front being to low after he put the 350 in)
  #28 (permalink)
Old 10-09-2004, 06:36 AM
Tazz
what combo to run...
350sbc and th350 trans. I think there are kits out there to help you out.
Tazz
Rat Rods Rule!
  #29 (permalink)
Old 10-12-2004, 03:48 PM
tirefryin_s10's Avatar
Last journal entry: 58
my truck has a very mild 350 in it with a well built th350 and a 2500 stall in the rear i have 3.73 gears and a mini spool at the track with 295/50/15 street tires it did not hook up very well giving me a best e.t of 14.511@97 mph not bad considering how mild my engine is , but either way it sure is fun
  #30 (permalink)
Old 10-12-2004, 07:07 PM
Last journal entry: Some pics
Just to be different I always wanted to put a ford flathead in an S-10.
