best engine swap for 65' rambler american and 63' rambler american? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-13-2011, 02:15 PM
whats the best engine to use in a 65 rambler amer. and a 63 rambler amer. ?
Old 11-13-2011, 02:54 PM
Wiki Edits: 31
AMC 290/304/360/401 will bolt into the '65.. '63 takes some cutting to put anything other than an original 196 6cyl into
Old 11-13-2011, 04:19 PM
If I stay with the 196 ci can you hop them up?
Old 11-13-2011, 04:38 PM
Wiki Edits: 31
Sure. cam can be reground, and The factory had a 2bbl carb option, along with a dual carb offered in the 1950's in the Nash's
Old 11-14-2011, 01:48 PM
best engine swap for '65 rambler american and '63 rambler american
Nash produced some top flight inline sixes in the '50's. Some even came factory stock with dual carburetors. They were no slouch for power. Just never really caught on in the main stream. I know of one now in a Rambler two door that garners a lot of attention when he attends the Nostalgia Drags in the San Joaquin Valley. I'll bet there are some still out there with the recyclers.
Normbc9
Old 11-14-2011, 02:59 PM
Okay,spree001 here. I'm new here and yesterday I asked about engine swaps in 63 rambler americans and 65 americans. I guess my bigest problem is air conditioning. I want a strong enough engine to support that. I'm not really looking for a hotrod as much as i'm looking at AC. It gets hot here in Georgia. The 63 has a flat head I think. Bought from a relative unseen. THe 65 has the ovh valve 196. My other problem is suspension and sterring. Any way to upgrade on a reasonable budget? thanks
Old 11-14-2011, 03:38 PM
68NovaSS's Avatar
Wiki Edits: 9
Welcome to the board.
Have you looked at some of the aftermarket AC manufacturers? Vintage Air and Classic AutoAir come to mind, and some are under dash units. Google aftermarket air conditioning.
Old 11-14-2011, 03:42 PM
thanks 68novaSS. I'll try that.
Old 11-14-2011, 04:02 PM
best engine swap fpr '65 rambler american and '65 rambler american
The Nash engines I' referring to are both OHV 6 engines but Rambler was owned and produced by American Motors who also owned and built the Nash motorcars. The engines will fit believe me. I've seen many conversions. Thi sin't a first time venture by any means.
Normbc9
Old 11-14-2011, 05:11 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Just a thought? How about the jeep 4.0 six..comes in efi and has A/C on it and can be readily obtained. Might be an option for you..
Sam
Old 11-14-2011, 09:05 PM
Thanks, Highball and Sam. Will the 4.0l fit in the 65' ? I know the engine bay is shorter on the 64-65' models than the 66-69' models.
Old 11-15-2011, 12:54 AM
Wiki Edits: 31
the 4.0l will fit in the '65, but not with factory A/C. the 232 was avail that year, but not with A/C.. 4.0L is not even close to fitting the '63.. The 196 will work with A/C as '64-'65, the Americans used 196's for cars with A/C
Old 11-15-2011, 12:56 AM
Wiki Edits: 3
I think that measuring the jeep engine bay and comparing the length to the Rambler bay would tell the tale on how close the 4.0 would come to fitting.
Sam
Old 11-15-2011, 01:02 AM
Wiki Edits: 31
Sam
Jeep 4.0L is the same length as the 232 that was used in the '65 and could even use factory mounts. It would require a CJ5 or '65 Rambler 232 short water pump, as the 232 used that year in the American. Length isn't the problem on the '63, the front suspension is 'large' and the 2 inner fenders take up a lot of engine compartment space, which really can't be mod'd
Old 11-15-2011, 10:13 AM
I'd use a Rolls/Merlin V-12. Once you cut the hole in the firewall and dash you might find it a little crowded in the front seat but you'ed have enough poop to run any kind of A/C you'ed want!
1960 Rambler American engine swap Ramblin' Man Hotrodders' Lounge 35 05-16-2013 08:27 PM
1965 AMC Rambler American Engine Swap imaginaryderek Engine 34 08-13-2012 03:33 PM
rambler american engine swap bnsurvey Engine 3 11-30-2011 04:10 PM
60 Rambler American rear end swap? bubbles Transmission - Rearend 4 04-29-2010 10:57 PM
'65 Rambler American engine swap matt167 Engine 10 06-21-2008 09:45 PM
