which is the best FORD engine??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2002, 11:50 PM
New Member
Talking which is the best FORD engine???
i am trying to get a pre 70's ranchero
for a project.
i want alot of power for pure street racing and the occasional strip performer. im lookin for about 400+ HP. this will only be a weekend racer with a 4 on the floor baby!!
i was thinking about a 302 but that would be kinda small compared to what the chevy boys are running(although the stangs seem to do pretty well with a 302), so i was thinking about a 351C.
should i try cramming a BB in this thing?
if i get one with the little 6cyl, how easy will it be to swap in the v8?
does anybody have any clue to what a pre 70's ranchero weights?
THANKS everyone
Old 05-04-2002, 06:41 AM
dmorris1200's Avatar
doesn't play well with others
Post
Well that's a lot of questions in one shot and I'm sure their will be many opinions. 4 Jaw Chuck says something like, I like them all, some more than others, cars and girls that is. Well add engines in their and that's kinda where I stand. Any engine can be built to a killer, some easier than others. If you're thinking small block I've always liked the Windsors. But a 390 big block in a Ranchero wouldn't be so bad either. As far as you stating a 302 seems kind of small what do you think would win a race between a blown 600hp 302 and a 4-barrel 350hp 350 engine. Just because you have less cubic inches doesn't mean you can't build power. Look at what some of the 4 cylinder race engines are putting out. The 302 is probably about the easiest to get parts for the swap, if you go small block. No matter what you go with you can make 400hp out of it. I've had a lot of fun with big blocks and small blocks as well.
BUILT FORD TOUGH
Old 05-04-2002, 06:54 AM
Thumbs up
My opinion is if I was to build a ford it would be a 460 it dont take much to get these creatures to go.but the small block 302 is not a bad choice either.( wrenchturner )as far as 6 to V8,engine mounts,coil springs,radiator.good luck its all good.( wrenchturner )
[ May 04, 2002: Message edited by: wrenchturner ]</p>
Old 05-04-2002, 11:01 AM
4 Jaw Chuck's Avatar
Post
Awww man, you don't ask the easy questions do you. Well I have a certain fondness for some Ford powerplants, here are the engines and why I like them.
-2.0 Litre Kent, A friend of mine had one of these in a Ford Cortina that was tuned to almost 275 HP. Redline was 8500 and would spin to 9000 if you weren't careful, no wonder they were used in SCCA racing for their bulletproof reputation.
-2.8 Litre V6, these were intially installed in the mid seventies Capri's and featured solid lifter cams and could be had with 4 bbl carbs, easily turning 7000 rpm with forged cranks and heavy duty rods, they didn't become popular here because of the german design but were highly revered overseas where they were raced quite successfully. Very narrow 60 degree design fits just about anywhere and they were used in the mid eighties Bronco II and later converted to hydraulic lifter in the 2.9 litre. These later engines had very poor head design for emission purposes. Very light and compact engines for the displacement.
-289 Windsor, truly the little engine that could with it's extreme oversquare bore/stroke ratio. For some reason people discount them because they are under 300 cubes (but not by much).
-302 Boss, bulletproof bottom end, huge ports and an exhaust sound that no small engine should be allowed to have. If you ever get the chance to take a ride in one with the shifts happening at 7500 your hair will stand on end. Thank the Cleveland heads for the sound.
-351C Boss or SCJ, a bigger 302 Boss only slightly heavier with that same sound. Completely different block mind you.
-427 FE Medium riser or high riser, I had a medium riser in a 68 Galaxy and although they are as heavy as lead they are torque monsters. Cross bolted mains are coooool.
-428 CJ, A better 427. I think one of the best street engines Ford ever built.
-429 SCJ or CJ, I have always wanted one of these. The Ford Hemi. The SCJ has the coolest valve covers I have ever seen.
-460, one of the least built up Ford engines out there and one of the least appreciated. Keep them under 5000 rpm because of the weaker rods compared to the 429. There is no replacement for displacement and these make a great street engine because they are so light compared to most big blocks by other Mfg's.
Personally my favourite is the 351 C just for those huge ports and sound, I have always wanted a 8000rpm capable small block under my hood and maybe one day I'll be able to afford one.
— Han Solo
Old 05-04-2002, 12:37 PM
Post
Holy cow Chuck, did he ask for the best Ford engine or every Ford engine made? You may as well include the 2.3 litre, built one of those up in a 74 MustangII once. Actually had that little 4 cylinder smokin' tires.
BUILT FORD TOUGH
Old 05-04-2002, 12:43 PM
Post
Im pretty partial to the aftermarket crank in the 460 for 514 cubes, lotsa N2O... otherwise, stick with the 302 or an FE... THE 302 WILL TAKE OUT ANY 350 CHEVY IF BUILT WELL, You just cant compare it to the chevy 305, etc...
Old 05-04-2002, 12:54 PM
New Member
Post
the 302 stroked to 347 is a strong street strip engine it doesnt coust any more to build that a good 302
a 351 stroked up to 427 will also get the job done in a big brick like a ranchero il go for the most tourqe i could get hope that helps
Old 05-04-2002, 01:03 PM
Post
If I'm not mistaken you can buy those stroked right from ford motorsport division.
BUILT FORD TOUGH
Old 05-04-2002, 01:57 PM
Post
Dmorris1200, as it says below my every post "I like-em all some more than others" lets just hope we don't get into a discussion about the female models that were produced in various displacements.
— Han Solo
Old 05-04-2002, 02:15 PM
Talking
some of em have a fair amount
Old 05-04-2002, 02:23 PM
Smile
Can we include pictures?? Please, Please, Please!!!
BUILT FORD TOUGH
Old 05-04-2002, 02:46 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Post
I am not just really fond of Ford stuff, but I would like to see those pictures. Good thread going here, I really enjoyed it. I think he ought to go with the 302 unless he just absolutly has to go big and then I would choose the 429. Now I am starting to sound like Chuck, but I kinda like a 351 windsor also, those can be built awsum.
Old 05-04-2002, 03:17 PM
Post
I guess that would be the only exception to the rule of "there is no replacement for displacement". :p
David your right, I had a 351W in my old 69 Stang and it was a strong runner to. Mucho Torqueo. Except I blew three of them by by putting rods through the block/oil pan. I have two I saved for wall mounting so that I will remember to shift sooner, seems even the good 1969 rods don't handle 6700 rpm for long. The last engine pulled the pin right out of the piston (cast crap) and swung around inside the engine making a sound I won't soon forget before exiting stage left. Lesson learned, most Fords need aftermarket rods to handle big RPM. Oh well there was a fantastic fireball that I was told looked really cool! Had to clean my shorts afterwards though?! When I tore that engine down to see if there was anything salvageable the cam was untouched and in perfect condition, very odd.
Would everyone like to see a picture?
— Han Solo
Old 05-04-2002, 03:41 PM
Lost in the 60's
Wiki Edits: 4
Post
Chuck, I really don't have anything against Rords. I just am used to talking like I hate them, for the benefit of my son-in-law. He is a Ford service manager, so I beat on him all the time. I really like Fords and Chevys both, just don't want him to know it. Ha Ha I made him mad three years ago and bought a new Chevy truck, that really tore him up, now I am building a Ford model A coupe with all Chevrolet stuff, he can't stand it, Ha Ha. He even told me that all hot rods with Chevy engines and trans had a Ford rear end pushing them, I said no way and put in a Chevy 10 bolt. I have fun agravating him, that what son-in-laws are for isn't it.
[ May 04, 2002: Message edited by: Henry Highrise ]</p>
Old 05-04-2002, 05:00 PM
Post
Well here for your enjoyment is Mr connecting rods, they slice they dice they pureé and will make short work of any engine block. Order yours today from any crying racer. :o
— Han Solo
