Best front clip for a 1950 chevy truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2006, 09:39 PM
Hello,
Can anyone tell me if the camero front clip is a good choice for my truck. Also any advice about the swap would be great. Are there any videos or books about it? I also was told a S10 might work. Please tell me what you think.
Thanks.
Old 01-26-2006, 09:58 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Been discussed many, many times on this board. Do a search. I prefer the fit of a Monte Carlo clip as shown here.
Old 01-26-2006, 10:45 PM
1950 chevy truck clip
Thanks for the great info. Would the frame on the 1955 be the same as my 1950?
Old 01-27-2006, 08:19 AM
Wiki Edits: 49
In a word, No. There are differences.
Personally I prefer the Mustang II IFS kit from Heidts. You can see one installed on my '53 here. It only one afternoon to do the complete installation.
Old 01-27-2006, 10:04 AM
Hey thanks for the info!
I am tring to decide which way to go with my 50. I am buildin it on the cheap so that is a factor. I do want it to ride great, and most of all be safe. The pictures and info you have is most excellent. I will have to use my lincoln buzz box to weld with so it wont be as pretty as a mig job. well thanks again, and any other advice would be great.
Lnova
Old 01-27-2006, 08:59 PM
Wiki Edits: 21
Sorry about that, my Partzheimer's seems to be getting a little worse! The front swap I showed using a Monte won't fit very well on an advance design chassis. Here is what I did for my '53. Keeps the stock suspension, 60,000 miles on a set of tires but I get power steering in the deal. A lot le$$ work than a clip too!
Old 01-28-2006, 07:22 AM
Don Meyer's Avatar
I have put Camaro,GM-G-body(78-88) & Must II under AD trucks. I prefer the G body because it is the same track as the AD & I like the way the trk drives & handles.
I also have the same IFS under my Rolls w/heavier springs.
Don
Old 01-29-2006, 10:52 AM
Thanks for the info
hey Don thanks for the help! do you have pics of the truck sub frame swap while in the process? and a description of the steps you used to do it. Thanks in advance.
Lnova
Swapping a Muncie SM465 to a TH-350 on a FS Chevy Truck TL-Iguana Transmission - Rearend 1 08-22-2004 06:54 AM
53 chevy truck help jstgtnstarted Suspension - Brakes - Steering 19 05-04-2004 08:43 PM
69 chevy truck front end change dragn azz Suspension - Brakes - Steering 4 07-23-2003 02:16 AM
1960 Chevy truck front disc brake swap importeater Suspension - Brakes - Steering 1 07-10-2003 01:16 PM
