Best fuel Pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2008, 07:27 PM
Best fuel Pump
I have a 1923 T Bucket with a blown 350 running 2 Holley 600cfm carbs. The engine puts out around 550hp. It is not used for racing, just for cruising. My electric fuel pump died on me last week and I need to instal a new electric fuel pump. The old one was a Walbro and didnt work very well. I am looking for some recommendations for a good dependable pump that will handle the hp and wont be to noisy. Right now there is no return line to the fuel tank. I want to stick with an electric fuel pump.
Any input will be appreciated
Thanks,
Rich
Old 01-26-2008, 08:57 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
For the street I have always had good luck and performance with Carter pumps. With a blower and twin 600 Holley's it might be enough for just cruising, or lighting em up on short burst's. Edlebrock makes one that is adjustable pressure wise, but it will hurt your wallet.
Old 01-26-2008, 10:28 PM
try the walbro 255 out of tank inline pump, good for like 500 turbo injected hp on my brothers car, even better for carbs, best part, only 70 bucks
Old 01-27-2008, 10:56 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I'm using a BG 220R, it's noisey and requires the return line and inline regulator, but pumps plenty through AN-10 lines. Have you looked at the Holley Blue pumps?
Old 01-27-2008, 10:57 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Make that a BG 220HR...
Old 01-27-2008, 02:16 PM
predator carb guru's Avatar
Mark Goulette
Talk to MagnaFlow or Aeromotive. Best pumps out there for electric.
Old 01-28-2008, 08:44 AM
mallory comp 140. quiet pump. Can't hear over the engine. a 14 psi pump that comes with a regulator to mount by the carb.
or get two comp70 or comp110 and run one to each carb. even quieter than the 140's. Can barely hear even with the engine off. set at 7 psi.
comp250's are loud.
use a course filter before the pump and mount as low as possible.
Old 01-28-2008, 12:48 PM
Thanks for all the info. I was looking at Holley's web sight http://www.holley.com/12-125.asp and noticed they have a new electric fuel pump that will handle up to 750 hp 7psi at 110gph, It has an internal regulator set at 7psi, a bit pricey though. The price is around $180.00 Has anyone used any of these pumps? It says it is quieter than traditional vane pumps. I looked at Aeromotive pumps but they don't have any dealers here in Oklahoma. There is an auto part store here that has a Holley 12-125 in stock but I wanted to see if anyone has any experience with them
Thanks,
Rich
Old 02-17-2008, 03:35 PM
I ended up going with the Holley 12-125 fuel pump. I get a steady 6psI at the carbs and it runs quieter than the Walbro pump that was installed. It was a bit pricey but I also liked the chrome finish. Thanks to everyone that responded.
Rich
Oil leaking near fuel pump..what the heck??? HotRodF100 Engine 13 01-08-2012 05:03 AM
93 Plymouth Acclaim fuel pump relay 78 monte Electrical 14 04-19-2007 03:09 PM
efi fuel line sizing / fuel pump Blob Engine 2 09-25-2005 12:25 PM
Electric fuel pump bad or not? HotRodMan Electrical 4 09-10-2005 09:47 PM
Lean backfire Camaro76 Engine 5 04-15-2003 05:45 PM
