-   -   best gear oil? (http://www.hotrodders.com/forum/best-gear-oil-222944.html)
db flyer 08-15-2012 08:58 PM
best gear oil?
I`ve got a daily driver 56 chevy 283ci. th350 with 3.36 gears in rear I believe.
What gear oil would be good for a rearend with a little end play or backlash after I let off gas at low speed? I have heard that synthetic, or Lucas additive may help. Thanks
vinniekq2 08-15-2012 09:27 PM
if its posi you need the additive to stop chatter. not much in the way of whale oil anymore,not that I would use it.
prostreet6t9 08-15-2012 11:27 PM
The lucas stuff Part#10001 is pretty good stuff. It's kinda like the old power punch. It's not a "cure all" by any means. If you have a clunk I doubt any gear oil or mixture will make it go away.
You could drain the oil and look for signs of excessive wear. If it looks good I'd use a little of the oil stabilizer and a good standard 80/90 or 85/140.
big gear head 08-16-2012 06:26 AM
I sold Amsoil for 15 years and their gear oil is great. I put it in hundreds of rear ends and never had any problems with it.
