best gear oil? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-15-2012, 08:58 PM
best gear oil?
I`ve got a daily driver 56 chevy 283ci. th350 with 3.36 gears in rear I believe.
What gear oil would be good for a rearend with a little end play or backlash after I let off gas at low speed? I have heard that synthetic, or Lucas additive may help. Thanks
Old 08-15-2012, 09:27 PM
vinniekq2's Avatar
if its posi you need the additive to stop chatter. not much in the way of whale oil anymore,not that I would use it.
Old 08-15-2012, 11:27 PM
prostreet6t9's Avatar
Differential/Driveline
The lucas stuff Part#10001 is pretty good stuff. It's kinda like the old power punch. It's not a "cure all" by any means. If you have a clunk I doubt any gear oil or mixture will make it go away.
You could drain the oil and look for signs of excessive wear. If it looks good I'd use a little of the oil stabilizer and a good standard 80/90 or 85/140.
Old 08-16-2012, 06:26 AM
big gear head's Avatar
High Performance Rear Ends
I sold Amsoil for 15 years and their gear oil is great. I put it in hundreds of rear ends and never had any problems with it.
Which gear oil? Madmax305 Transmission - Rearend 3 06-26-2011 09:26 AM
Gear oil? 2_Late_I_Won Transmission - Rearend 14 03-17-2007 03:22 PM
Info on Synthetic oil & gear oil Kenny G Hotrodding Basics 6 06-29-2006 10:13 PM
which gear oil to use? darom Transmission - Rearend 4 02-12-2004 12:45 AM
Gear oil Doug Renton Engine 2 11-19-2002 09:13 PM
