best glue for mirror to what looks to be plastic? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-24-2003, 12:01 PM
bullheimer's Avatar
NEVER use credit cards!
Post best glue for mirror to what looks to be plastic?
mirror fell off exterior mirror on my 72 CAMer-o, have a new one, looks like a plastic plate where it was glued to, old glue looks like old yellowed clear glue of some kind, after i scrape that crud off, what should i use to glue it back on. want to make sure it doesnt dissolve the back of the mirror.
[ January 24, 2003: Message edited by: bullheimer ]</p>
Old 01-24-2003, 01:44 PM
jwcnj45's Avatar
Post
I have used silicone sealer for this and it works well. Put a couple of dabs of it on the plastic backing and temporarily tape the mirror in place till the silicone cures. Should hold just fine.
Old 01-24-2003, 02:30 PM
awsum34's Avatar
Post
Alot of the new cars are going with the double stick tape, (like the tape used for side molding)
Old 01-25-2003, 11:14 AM
bullheimer's Avatar
Post
morecheese greasyass! i have sillycone, not doublebacked tape, so i'll be trying that this time. byw the above is spanish for much thanks!
Old 01-25-2003, 11:19 AM
dmorris1200's Avatar
doesn't play well with others
Post
Super Weatherstrip Adhesive (in tube, not spray can) is yellow in color. That might be what was on there. Stuff is pretty strong but takes a while to dry.
BUILT FORD TOUGH
Old 01-25-2003, 09:42 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
Late model widshields are glued in with a urethane glue. I would get some of that stuff. It will not come off again guaranteed.
chris
