best grit sandpaper - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-23-2013, 04:03 PM
best grit sandpaper
whats the best grit sandpaper to use after 2k primer to get ready for top coat,thanks
Old 04-23-2013, 08:10 PM
Block your 2k with 180-220, then sand with 400-600 prior to base.
Old 04-23-2013, 08:40 PM
thanks for the info
Old 04-23-2013, 11:10 PM
put up or shut up
at work I like doing the first round of priming with 120 then reguide coat it and then 150 over and over until the first area of metal pokes up. I think it's absolutely crucial to sand the guide coat multiple times, especially on your first round of primer. If you hog on your primer with 3 coats for the first round and you guide coat and re-guide coat multiple times you will make things a lot easier the next round. If you don't mind cutting past the primer on the first round you probably won't cut thru on your next.
Sandpaper Grit - Please Explain nova69 Body - Exterior 3 12-25-2006 12:20 AM
sandpaper grit ucmung Body - Exterior 5 12-04-2006 07:10 AM
Sandpaper grit on NEW panels Irelands child Body - Exterior 8 05-23-2006 09:54 AM
What grit sandpaper is this? Z-Money Pit Body - Exterior 1 05-30-2005 11:23 PM
what grit of sandpaper DOBIED Body - Exterior 1 02-14-2003 11:51 AM
