The Best Gun for Clear Coats? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-03-2011, 03:03 PM
Hey everyone. So my situation is that I have friends who let me use their shop because I help them out when I can. And a few weeks ago I painted a car with their Devilbliss and the base coat went on perfect but the clear coat had big orange peel. I hate orange peel so regardless it was my plan to cut and buff it, but that ****s really hard and I'm sick of doing it. I plan to paint a car every month from now on and I need them to look show car good.
So I have no price limit on the clear coat gun but I'm pretty poor so I'd like to know where to get that gun for cheap (not used though). Right now I think the best gun for shooting plain clear is the Iwata Supernova with the 1.4 platinum cap, but I could be wrong so that's why I'm making this thread.
Thank you.
Old 09-03-2011, 08:08 PM
gto_ron's Avatar
clearcoat gun
This topic has been brought up many times before and you'll get different opinions. I use the Supernova 1.3 for clear and am very pleased with the results. It's too slow for production work but that's fine since I'm not a pro. The Sata is comparable to the Iwata and lots of members get great results with Devilbus, Sharpe, etc. I guess what I'm getting at is maybe the problem was the painter and not the CC gun. This is not a slam at you but is based on problems I've had in the past.
regards
Ron
Old 09-03-2011, 10:25 PM
Well you're right I'm not good at painting but that's besides the point because no matter how good I am I'm always going to get orange peel with the gun.
So how come you didn't want the 1.4 tip for clear? I thought that one was supposed to shoot it smoother. And could the clear gun shoot base with out any problems? Or should I just use the Devilbliss at the shop?
Old 09-04-2011, 11:21 AM
gto_ron's Avatar
CC gun
I bought it because Iwata recommends the 1.3 for clear plus I got a good deal on it. A 1.4 is fine for both base and clear also. Basecoat is kinda hard to mess up as long as the prep work was done right. Clear requires more skill to lay out smoothly. Search the Forum for the article on spray gun tuning. Sorry I don't have the link handy.
regards
Ron
Old 09-04-2011, 11:51 AM
I use a HVLP gravity feed Binks gun with a 1.4 tip. I use it for both base and clear coats without ever having a problem. I only use a separate gun for primer's and feather fills. I suggest if your going in the market for a entry level gun... I'd use a Devilbiss or a Sharpe. If you want to spend the big bucks I'd go with a Devilbiss, Binks, Iwata, or a Sata.
Old 09-04-2011, 08:25 PM
Yeah I can just use the devilbliss at the shop but I'd rather get something that has the technology to give me a very close to perfect finish.
So I guess the Iwata Supernova 1.3 clear gun is the one I should buy? I'm sure I read that 1.4 was better but maybe I'm wrong.
Does anyone know where to get a good deal on this gun (for a Canadian)?
I don't want the cup because I want to use the PPS system.
Old 09-04-2011, 08:39 PM
mitmaks's Avatar
Last journal entry: Grille
I like my Sata
Old 09-05-2011, 08:28 PM
Old Fool's Avatar
Get the 1.4
Old 09-05-2011, 11:00 PM
And should I be getting the LS400H or just the regular LS400? I don't know if I see many people on the internet selling those.
Old 09-09-2011, 09:11 PM
Go and do a search on this and other forums for spray guns. There are hours and hours of reading to do on this subject. Like others have said, you will get a bunch of different opinions.
But as gto_ron suggested, in most cases the painter has more to do with the finish than the gun that is used. It is just a matter of experience.
It can get expensive buying a bunch of guns. I think if I did it all over again, I would buy one really good gun and a cheap primer gun, and use the good gun for base and clear.
Old 09-10-2011, 08:34 AM
try spraygunworld they are cheapest,or ebay there were some pretty good deals there too.i almost bought an devilbiss tekna,untill i bought a used lph400 from ebay for $180.
Old 09-11-2011, 08:25 AM
deadbodyman's Avatar
Wiki Edits: 11
You'd be better off changing your clear.... spending 700.00 on a clear gun wont help you lay it down like a pro but you might look like one ....the clear I use(SPI unversal clear) sands ez and buffs like butter a month later ...You start with a 1.4 tip ,spray it like you want it to look.
Old 09-11-2011, 08:57 AM
Yeah but I want to paint cars with out having to sand the clear coat, that stuff takes too much time. I'm really not that bad with the devilbliss, pretty sure I can paint with it as good as anyone can. But I want something that can help me eliminate the sanding.
I think what I'm going to get is the LS400H 1.3 clear gun, I think that makes sense.
Old 09-11-2011, 10:22 AM
Wiki Edits: 11
A 1.3 tip is a 1.3 no matter who makes it. I have a Sata with a 1.3 and it sprays base fantastic using much less material than the 1.4 but it wont spray the good,high solid clears very well unless I sloooow way down , my 1.4 on my old Iwata is perfect it lays down clear fast and like glass everytime...You cant go wrong with a great gun like the 400 but I would definitely go with a 1.4 tip for the clear regardless of who makes it
Old 09-11-2011, 10:32 AM
Gosh darn it, now I need to get this figured out. For every person that says 1.3, there's a person who says 1.4.
The person who recommended the LS400H 1.3 clear was the guy that runs SprayGunWorld.
So could is be that one kind of clear would be better for 1.4 where one might be better for 1.3? If so what clear should I be using with what gun? Or should I even worry about that? I just really want to be laying the most flat clear coat that I can.
coats of clear slickss96 Introduce Yourself 1 10-17-2010 10:58 AM
coats of clear slickss96 Introduce Yourself 2 10-17-2010 10:57 AM
Rubbing clear coats. bermjuls Body - Exterior 7 04-08-2008 11:25 PM
Time between coats of clear redboat Body - Exterior 6 02-12-2007 03:16 PM
Do more coats of clear..... Rick WI Body - Exterior 2 04-08-2005 09:30 PM
