Best gun to move fast for clear? - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Body - Exterior> Paint
Old 09-28-2013, 01:17 AM
cutthroatkid's Avatar
two cups of tea
Last wiki edit: Need more horsepower for my 305 Last photo:
Wiki Edits: 2
Ok so as you probably know Im using the devilbiss* flg4 & its good for base but when it comes to clear I reslly have to move slow to get the clear on nice & wet if I dont move like a granny then* my cleat comes out looking like sandpaper.So I want something that I can move fast with & lays clear like glass.Cost is not a issue though Im far from well off I buy the best body tools I can afford but sometimes I settle for the generic stuff cuz I can make it work but I know the gun for clear is the most important tool in my arsenal when it comes to paint just liks my welder is when it comes to bodywork.
***************** And since Im getting good results with a 200 dollar gun I know that one with a bigger price tag will pay for itsself My good friend suggested a gti but I havent got to ask him about speed on it,so...best gun to lay clear fast?Please & thank you
********** Please excuse any typos or terseness: this email was sent from my mobile and I have clumsy fingers.
Old 09-28-2013, 06:11 PM
two cups of tea
Wiki Edits: 2
thinking about the tekna copper or thr sata rp
Old 09-28-2013, 10:42 PM
carolinacustoms's Avatar
Automotive Extraordinaire
Sata 90 or Sata Rp with a 1.4. I have a RP and my brother uses a 90 both will lay most any clear like glass, but you gotta keep moving or you'll lay it right off in the floor.
Any of the Sata RP guns (RP, 2000 rp, 3000 rp, 4000 rp) should do well for you, but the 90 is probably the best ever made, but they are getting harder to find. Check Ebay you can usually get a decent Rp gun in the $300 range.
Here's an example of the 90:
Kelly
Old 10-01-2013, 08:08 PM
Preacherman's Avatar
agreed...if you can swing it, any Sata RP gun is the way to go...well, a 90 then the RP's..lol! Iwatas are good guns also but seem a good bit slower to me.
Old 10-01-2013, 08:11 PM
also, the above video is the Allchem Virtus one coat clear so he's going a bit slower than normal. If that was a 2 or 3 coat clear you could roll a far amount faster with that same gun.
Old 10-12-2013, 05:08 AM
cyclopsblown34's Avatar
Colorsanding painter
I prefer my 3000 digital RP with 1.4 and my son prefers my Satajet RP. They both let you get around a vehicle quickly with excellent material build.
Old 10-19-2013, 02:43 PM
you have to turn up your pressure when spraying clear and adjust the material knob out, that is most likley your problem, i dont think that the gun cant spray clear.
Old 10-19-2013, 07:16 PM
another thing, just test out your pattern on a test piece and adjust from there. I can get similar results from a devilbiss starting line as I can from a finishline model, however i would have to adjust the two differently according to the situation because they have different characteristics.
One gun for base and clear? Knucklebustn68 Body - Exterior 11 07-01-2012 12:47 PM
The Best Gun for Clear Coats? piercetdg Body - Exterior 15 09-12-2011 06:46 AM
perfect clear gun #!new Body - Exterior 14 01-25-2011 07:23 PM
low priced spray gun/detail gun for primer/base/clear and ghost flames jrmy_1 Body - Exterior 15 06-08-2008 06:38 AM
PPG clear coat help needed... Fast!! Z-Money Pit Body - Exterior 5 06-13-2006 08:14 PM
