Dont know if you can find one or not, because they have been discontinued but a Sharpe platinum with a 1.3 tip and a 2000 air cap would spray concept pretty good and it only uses 7.5 cfm................so keep an eye out.
I wouldnt worry so much about who makes the gun as long as it has a tip no smaller than a 1.3 if your color has metallics and no bigger than a 1.4 for solid colors and clears...a 1.4 is a pretty good medium that can be used for both with a little practice but a 1.3 is a little too small for high solid colors and clears and will tend to spray dry...If I could only have one I'd go with the 1.4..
Good advice so far, I was thinking of a 1.3 or 1.4 as well. We're shooting solid old school original colors, blue and white. 4 coats maybe 5 and a wet sand afterwards. The bus is completely sealed in K38, wet sanded with 600 so its smmooooooooth as glass right now. I'll make a decision here in a few days so if anyone else has some recomendations for PPG Concept let me know!
![]() thanks! |
See this thread, post #4, my post. This is how I solved my small (3 hp) air compressor problem, with a HVLP gun.
need suggestions for compressed air filtration / desiccant unit Now, for the gun. My suggestion, is to buy a higher end mid grade gun, and learn to use it. In my opinion, by far the biggest variable in spray painting is gun technique. I would plan on keeping the gun. I am guessing the loss of value in a spray gun is about as dramatic as the loss in value of a new car, the moment you drive it of the lot. |
| Single stage vs Two Stage vs 50% base/clear | a1960apache | Body - Exterior | 51 | 09-19-2010 06:16 AM |
| Single stage help | esahlin | Body - Exterior | 7 | 07-20-2008 08:13 AM |
| help with single stage | drewmangoo | Body - Exterior | 8 | 01-06-2007 09:05 AM |
| Single stage and duel stage air compressor? | DeathByGreaser | Body - Exterior | 24 | 10-19-2005 06:33 PM |
| single stage or used 2 stage? | zimaad | Garage - Tools | 9 | 08-04-2005 08:19 PM |
