Best (head) gasket scraper? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-23-2012, 08:04 PM
maverickmechanic13's Avatar
I'll have a beer with that.
Last journal entry: My Trans Am
Hello all
As a matter of preference, in everyone's opinion - what is the best gasket scraper? Especially when it comes to dealing with scraping off the pesky graphite residue of an old head gasket stuck on the block or cylinder head?
I am mostly curios of what others are using to scrape off the head gasket remains from the block. As far as the heads go, i personally always send the heads to get checked by a machine shop, and have them cleaned and cut before they get set atop of new head gaskets.
I've used razor blades at various angles against the deck, scotch-brite pads, and even plastic ice scrapers (so i dont gouge the block). What are you guys using?
Old 03-23-2012, 08:12 PM
vicariouslynova's Avatar
CHEVY OR BUST
people may cringe at this, but as a mechanic by trade, and not a car mechanic, I use a 4" grinder with a wire wheel attached. Cover the valley with rags and old lifters (lifters to keep the rags from getting sucked up in the wheel), AND BUFF HER THILL SHE SHINES. Clean the cylinders out with a clean rag, then blow them out with an air gun to get the small stuff. GOOD TO GO!
DO NOT USE A STAINLESS STEEL WIRE WHEEL AS IT WILL HARM THE SURFACE. AND DO NOT "CLEAN" THE PISTONS AS IT MIGHT BE TEMPTING!!!!
I just did steel head gaskets on my boys 307 last weekend using the same method described above.... NO ISSUES
WELL JUST ONE>>>> WE FOUND OUT THAT HIS MOTOR IN HIS 70 NOVA IS A #'S MATCHING ENGINE!!!! This we can live with!!!
Old 03-23-2012, 09:49 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Sharpen the end of a flat file. It works great. Files are stiff and won't bend like putty knives.
Old 03-25-2012, 06:33 AM
Old Fool's Avatar
I use 2 things, a putty knife and a honing stone.
I take the putty knife and shorten the blade to about 1 1/4 in long, then put a sharp edge on it, Works great.
After scraping, I take a dual grit hone stone and some WD40 and stone the surface.
Any remaining gasket pieces show up real quick.
Once the surface is truly clean it will take on a nice sheen.
That is all it takes to be ready for a new gasket.
http://www.sharpeningsupplies.com/No...ne-P179C5.aspx
http://www.reddevil.com/index.php?l=..._detail&p=1206
Old 03-25-2012, 09:11 AM
delawarebill's Avatar
gasket removal
i have a razor blade knife.... it lever type and folds into itself and the razor works like a scraper after u unfold it..
Scotch Bright disk or gasket scraper on block bajamedic Engine 9 07-29-2011 03:13 PM
Unable to separate head from block due to head gasket sealer Nostalgia Hotrodding Basics 18 02-02-2011 01:12 PM
cracked head or head gasket???? onebadmerc Engine 12 12-04-2008 12:10 PM
Head Gasket? chewyscool Engine 1 07-29-2008 03:34 PM
oil on head bolts and head gasket bullheimer Engine 7 05-25-2004 04:50 PM
