I can`t believe how often this comes up. First, if you use paper gaskets you must soak them in water 24 hours so they swell and hold moisture.
I don`t waste my time on any other gasket other than stock fel pro exhaust manifold gaskets. These cost about 4 dollars and they are mesh steel so they don`t burn out easy, they are also open slotted so you don`t have to remove all the header bolts to install them. If your headers and bolts are fresh then you will have to check the header bolts every 2nd time it`s been drove after it`s cooled. The header bolts will work loose when new and they don`t stop until they are seasoned in. Another benefit of the exhaust manifold gaskets is they are often reusable, if something comes up and you have to remove the header you can drop them right back in and they`ll seal up.
