Best headgaskets for blower motors - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-02-2002, 03:54 PM
roys63's Avatar
Post Best headgaskets for blower motors
OK Anyone know of headgasket that will take high Boost with out oringing the block? I have tried Fel-pros best made for the GMs with the SS fire rings and thay work for awhile.Or what is the max boost you can run without? This is run most on the street with a SBC with iron heads, Thanx
Old 10-02-2002, 05:02 PM
4 Jaw Chuck's Avatar
Post
O-ring the block if you are having problems, are you retorqueing the heads after running the engine after installation? I have found that non-retorqueing gaskets are anything but...they always need retorqueing when I check the torque on them.
— Han Solo
Old 10-02-2002, 05:47 PM
roys63's Avatar
Post
Yes i allways retorque never trusted the No Retorque Deal!I have no problems till i get to about 12 lbs boost it doesn't blow the gaskets they start leaking or weaping pres to the cooling system , no overheating just a lot pres build up in rad running a 22 pound cap that tests to about 20 i have presgauge in the system i can see run up after running hard but never when just running around. yes time to o-ring or just be happy with the 6-8 pounds and no Cam 2 to buy!You know this HP thing is a MADDNESS!
