I knew what line of cam it was as soon as I saw the vast seperation in the dual pattern and then the 107LSA.
In my opinion the best head for you combnation would be the AFR-195 CNC comp heads, but here are a few decent alternatives that dont cost quite as much; DART pro 1 200cc, RHS pro action 200cc, Brodix IK200's, Or even a bit cheaper would be the DART Iron Eagle Platinum 200cc heads. In my opinion you need to go with a dual plane intake like the performer rpm, and then I honestly believe that you would be best off going with a 750 vac secondary carb instead of the double pumper carb.
