Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Best Heads and intake for my 383 and cam
Old 10-10-2012, 03:32 PM
cdminter59 cdminter59 is offline
Originally Posted by 06-z0sick View Post
Hey guys currently have a 383 stroker with the following set up:
-4.030 bore
KB 18cc pistons
5.7 rod
235/249 5.22/.509 107 lsa at .050 Camshaft
0 deck height
9.6:1 Static compression
8.27:1 dynamic compression with my cam
Stock 64cc swirl port heads
Weiand X-CELerator Single Plane intake manifold
Looking for a great set of heads (give me best heads and lets say an okay set that will do the job) and matched intake and carb setup to make the most power out of this little 383 street motor.
What would be a good size carb to run on this ?
What would be the max rpm i could see out of this? Solid roller?
Let start out by asking what is your main purpose for this motor? Also what car or truck is this motor going in. List the vehicle, weight, the stall converter size, rear end gear ratio, and rear tire size.
The Following User Says Thank You to cdminter59 For This Useful Post:
techinspector1 (10-10-2012)
