Best Heads and intake for my 383 and cam - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-11-2012, 07:27 PM
Banned
Originally Posted by 06-z0sick View Post
I have an 89 block, what style AFR heads would i use?
These:
AFR - Airflow Research 1041 AFR SB-Chevy Street Aluminum Cylinder Heads
or can i use the style with the non center valve cover bolt holes?
And for the double pumper carb do u reccomend mechanical or vacuum secondaries?
a double pumper is mechanical secondaries, vacuum secondary carbs only have one accelerator pump circut.
Any style of heads will work with that block, you're probably best off avoiding center bolt valve covers.
383 stroker help/ what heads,cam hus123321 Engine 4 10-15-2010 08:50 AM
383 intake/cam questions boredandglued Engine 3 07-17-2009 06:40 AM
blown 383 heads and cam smokin63 Engine 0 02-24-2008 11:44 PM
Beginner with new cam,heads,intake install fast times Engine 5 08-18-2005 01:55 AM
383-- use the vortec heads? what cam? slonova Engine 10 02-02-2004 12:45 PM
