No one uses those end gaskets. Gm doesn't even supply them anymore, they include a tube of RTV. You need a 1/4"-3/8" thick bead at the front/rear. Then let it set up 20-30min. before installing the Intake. Surface must be clean = NO oil before applying RTV. Also put a small/thin bead around water ports on side gaskets.
Well i will reorder the intake gaskets. Now if i dont need the front and rear gaskets then what is the best way to use rtv and do it right. There are holes were the gaskets go should i just rtv around them or put some in them. This is my second time doing this and i dont want to do it again. Thanks
If you are talking about the small holes on the surface where the end seals go. They are there to locate the seals. Just apply the thick RTV bead over the top of them, they will fill when the Intake is set in place.
The best intake gaskets are the ones that match you intake ports on your heads. What does the head manufacturer recommend?
Has your block been decked, heads cut? This may affect how the intake gaskets fit. FelPro makes different intake gaskets based upon intake port size. They also make thicker than stock intake gaskets. What heads are you using, what intake, and what FelPro number gaskets failed? |
The block was not decked as far as i know. Im using a set of 882 heads with an edelbrock rpm performer intake. The first set of gaskets came in a complete gasket kit from felpro.
Try using the Print o Seal style gasket.
Ok i am thinking of trying those printoseal gaskets. They do come with the end gaskets too. Now will they work with an aftermarket intake and not leak? Just so i know what port size would the 882 heads have.
Throw away the end gaskets. Clean the ends well with brake clean on a rag to get rid of all the oil. Lay down a 1/4 thick bead of black RTV, be sure to set the manifold straight down so you don't wipe the RTV off. Depending on what configuration intake you have, sometimes you can install a couple studs to help with initial alignment. I have done hundreds this way and they will not leak. No one who has done this for any length of time uses the end gaskets, they just don't work.
Artificial Intelligence is no match for Natural Stupidity Chet |
X2 Even the OEM's quit using the end seals- they use a material like "Right Stuff". FelPro ships their gaskets w/their black RTV- works great. Once you've done one right w/the RTV you'll never go back to those damnable end seals.
Does anyone besides me remember when there was no RTV? Then, it was pretty much Permatex #1, #2 or #3.
| 92 SBC intake gaskets | Eric64 | Engine | 3 | 04-24-2009 08:50 PM |
| Sealer on intake gaskets ? | junkyardjeff | Engine | 3 | 05-15-2007 11:28 PM |
| Good old Chevy intake gaskets | shoes | Engine | 3 | 03-25-2007 07:33 PM |
| Intake manifold gaskets for alum. heads and intake | mustang66maniac | Engine | 6 | 02-20-2004 11:19 AM |
| port matching the intake. | Jmark | Engine | 9 | 12-08-2003 10:13 AM |
