I have a 1986 small block 305. I dont want a automatic transmission I want a manual transmission. What are some good manual transmissions for this engine and good companys to buy it from?
Really depends on your application. Depending on your axle ratio and what you want to do with the car. A W/C T5 would be nice, but at about 350hp it gets kinda dicey if you really hammer it.
Any GM 4spd would work as long as you match the 1st gear of the trans to the axle ratio. Divide 9 by your axle ratio; the answer is approximately what 1st gear you should have in the trans. If you wanted to use 3.08s for example; 9/3 = 3, so a 2.88 1st T10 would be fine.
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
