best needle size for vinyl. - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2009, 01:59 PM
stumpy1972uk1's Avatar
newbie
hi guys , i have recently purchased a toyota walking foot sewing machine with the intention of doing my own seats for my vauxhall victor project , what size needle would be best for the vinyl , the current needle supplied with the machine which i have no idea what size it is seems to cut the fabric. any help greatly appreciated. cheers ade
Old 11-09-2009, 06:56 AM
DanTwoLakes's Avatar
Wiki Edits: 22
You should change the needle right away. It's more likely a burred or bent needle. Depending on your machine, you should be able to use anywhere from a size 18 needle to as much as size 24, with the smaller the number the smaller the shaft of the needle. None of them should cut the fabric. If you have a home type sewing machine, it may not be able to handle what you are trying to sew. Also, you only need to be sewing 5 or 6 stitches per inch. Any higher stitch count per inch and you could cut the vinyl.
Old 11-09-2009, 03:19 PM
newbie
hi Dan , thanks for the reply ,the machine is an toyota LS2-AD331LP industrial walking foot sewing machine. the needle was new , after reading your thread it points to the stitch length , ive ordered some 19s needles. i will decrease the number of stitches and give it a go. thanks for your advice . regards ade
Old 11-09-2009, 03:55 PM
Wiki Edits: 22
Remember, just because a needle is new doesn't mean it didn't get bent or burred somewhere along the way, but changing the needle to a smaller one and increasing the stitch length is a good idea.
holley jet size markzepp820 Engine 2 03-31-2007 10:23 PM
Garage size options 66GMC Garage - Tools 62 02-28-2007 09:32 PM
Is There An Exhaust Size Rule Of thumb To HP Rating? 64nova Engine 10 11-06-2006 11:59 PM
87 Lincoln Rear Caliper Banjo Bolt Size? sonicweb Suspension - Brakes - Steering 2 08-30-2006 01:00 PM
S-10 tail pipe size catscan4free Engine 3 02-23-2004 02:34 PM
