Best Option for prepping / painting frame / chassis? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-05-2012, 11:38 AM
Iím starting the teardown and build of a í65 Chevy truck that will be my sonís first ride. This is going to be a budget build, but we are doing a frame off.
I plan to be starting on the frame clean up shortly. Iíll start with the grinder and paint remover discs first, and see how that goes. Next up would be chemical treatment, lastly blasting.
Remember, I said BUDGET. And weíll be doing every bit of this truck ourselves, including paint and body.
Iím not really keen on LEAVING RUST on the frame (itís actually not bad, mainly light scale and surface see the pic below):
So Iíll be grinding and stripping. If that doesnít work Iíll go the chemical removal route. Lastly, blasting.
Which of the following do you think would be the best for durability and finish vs. cost?
1. Spray cleaned / prepped frame with epoxy primer and topcoat with a single stage urethane satin black.
2. Spray cleaned / prepped frame with a compatible primer and topcoat with something like John Deer Blitz Black.
Iím not comfortable with using POR or other rust paints, leaving the rust underneath. Maybe thatís just me.
This will be a DAILY DRIVER for the kid (likely SS urethane satin black for the paint as well, he loves that look as I do I) so itís not going to be a show truck.
Input?
Old 04-05-2012, 02:49 PM
hp246's Avatar
You may want to do a bit of searching. If I might suggest, forget about cleaning up the frame yourself. You will easily have more in materials if you follow the plan you've outlined than if you have a professional blast the frame. You can get it blasted for between $200 and $300. I saw a post recently that said $250. In addition, unless you are using the proper safety equipment, blasting can be very hazardous to your health.
As far as finishes, again, do a search here. There are a wide variety of products in a wide price range that will do the job. All depends on what type of application you want, and the finish you are looking at. Some possibilities are Imron paint, Epoxy Paint, POR 15, Rust Bullet, etc. Stay away from the Rustoleum. This topic is something like Mustangs and Camaros. Everyone has one
Good luck. have fun with the project. Great to see a dad working with his son on a project.
Old 04-05-2012, 03:53 PM
Last journal entry: V/W Outboard
Best Option for preping / painting frame / chassis?
Gents;
When it comes to Chemical cleaning, I do not Like it because
the Chemical gets between Reveted, or Spot Welded members.
There is NO way to neutralize those Fluids... I made the mistake of having a truck body Chemicaly Dipped. After a really nice paint job, the
Seams would blister under the paint. The Dipping people
said the Stripper would neutralize and be no problem... WRONG.
I have had the best luck, on Frames, using a Fine Grain Sand.
Things like Under Coating, Road Tar, and other Stuff will
need to be removed with Kerosene.
DO NOT use Gasoline!!! it is extremely Dangerous.
Just rent a Sand Blaster with Opperator Hood Gear, and, with Engine driven Compressor. Have the Rental people Prove that
it works prior to leaving their Grounds.
The sand comes in a Paper Bag. Most opperators will allow a small piece of the bag to fall into to blaster while refilling with sand. This "WILL" stop the sand flow.
Most novice blasters do not know how to adjust the blaster.
First; If the previous renter used very course media, it will
need to be totaly cleaned, or it will clog the flow. It is easy to flush.
Just turn on the air and fully open the "Sand Adjustment Valve" and
allow it to purge all the bolders, and gravel, and paper.
To blast;;; "First thing is"--- Completely Close the Sand Valve.
Then Add Sand, being carefull not to allow any thing but Sand to enter the blaster.
Open your "Air Supply Valve" and allow it to Purge the hose and nozzel.
Then slightly open the Sand Valve until there "is" Sand. That is "Enough".
Let the sand and air do their job. After all is opperating well, Play with the sand valve. Most people will Open to much Sand... All this does is "Belch"
globes of sand and do no good. That will also
Empty you Sand Vessel very quickly.
Never adjust the Sand With the Air OFF.
Find a place away from any thing you want to keep.
Keep the Compressor as far away as possible.
Find a place where you want to do some land filling.
Sand blasting is fun! Do not Blast today and Paint tomorrow.
Surface Rust is quick to show.
Happy Trails
bob
Old 04-05-2012, 06:02 PM
Last journal entry: My Last Hot Rod
Darn
I have to junk my car the frame is painted with good ole Rustoleum.... Its been 6 years though
Old 04-05-2012, 07:00 PM
hp246's Avatar
Nope, just repaint it. Seriously, my experience was painting a frame that was blasted first with Rustoleum primer, them top coated with their product. It didn't last one Michigan winter. I had a mess. Started over with the whole process. Use POR 15. Its now been on for about 8 years. No rust, no chips (I live on a dirt road). YMMV
Old 04-05-2012, 09:17 PM
Around here it would cost at least $350 if not more to get a frame sandblasted, not to mention most want to prime then as well. I have access to a blaster, and media is cheap. Iím well aware of the health risks and needed safety equipment.
Iím not planning on spending a lot of money on trying different avenues. Using a grinder and a paint/rust removal disc or wire cup brush wouldnít cost me anything but time.
The ďchemicalĒ process I am referring to is using a phosphoric acid compound to get rid of rust and etch the metal for paint application. Iíve used it successfully on similar projects, and Iím actually using it right now to soak donor parts that have scale rust (control arms, suspension components etc).
Iím really leaning towards epoxy primer and a decent SS urethane on top. Just putting it out there in case someone has had a good experience with something else. Rustoleum was never an option.
Thanks for the input, itís appreciated. My son and I are looking forward to digging into this one.
Old 04-09-2012, 01:09 PM
Gents;
If you do deside to Sand Blast, DO NOT get carried away and try to sand blast the Fuel Tank. There are easer and cleaner ways to Die.
bob
Old 04-09-2012, 01:28 PM
Originally Posted by Bob Allen
Gents;
bob
No worries here...the gas tank is in the cab of the old truck.. LOL
painting chassis ricksautorestoration Body - Exterior 9 11-15-2010 10:12 AM
Prepping and Painting rms390 Body - Exterior 5 04-08-2010 07:33 PM
Need help prepping and painting plastic part Z2TT Body - Exterior 1 08-12-2008 12:14 AM
Prepping and painting new/dipped parts? tcruise Body - Exterior 5 10-17-2005 12:52 AM
chassis painting. 38 special General Rodding Tech 7 04-19-2003 12:19 PM
