Best overall 350 sbc block - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-30-2011, 12:34 AM
What years are the best 350 block to build a stroker with? Asking because I am not sure if there were certain years that may have been better than others or does it really matter?
Old 12-30-2011, 02:43 AM
psbaker75's Avatar
I'd say something from the 90s with a one piece rms and factory roller cam setup.
Old 12-30-2011, 06:30 AM
If you could find a 4 bolt with 2482 on the center caps and then it needs to pass a sonic test on the cylinders!!
Old 12-30-2011, 08:57 AM
i dont know much about the the newer style 350's builds, parts, clearences etc.. I need to learn more about them.. im more old school i guess. im taking more about the older blocks
Old 12-30-2011, 10:20 AM
chevy302builder18's Avatar
mr mighty mouse
Last journal entry: shes dropped!!
well, there is casting numbers, and there is nickel content and tin content. 010 high nickel block, better ring seating, harderned smooth polished after finished seating. Then theres the idestructible ones with a high nickel-tin content 020. If you know where this number is at(right where the timing chain cover goes right under it) then you should get a jist of what you have.
Back of the block also has these numbers
Old 12-30-2011, 12:25 PM
casting numbers i check to be sure what cid that it is yes but it is good to know some finer detail.. thank you
Old 12-30-2011, 03:49 PM
techinspector1's Avatar
Wiki Edits: 326
The block being referred to is the '96-'00 RPO L31 Vortec 5700 350 motor found in Chevy and other GM brands. Look at trucks and vans of those years. Heavier vehicles had 4-bolt main caps, but they are not entirely necessary for a naturally-aspirated street build or street/bracket build. This is still a Gen I motor, same basic design as the '55-'86 block. The heads are the best production heads ever produced by Chevrolet, one-piece rear main seal and roller tappet cam. Generally, the stock roller tappets can be re-used with an aftermarket roller tappet cam.
Inlet ports on the L31 heads are taller than heads used on '55-'86 motors, requiring a dedicated Vortec intake manifold. NOW HEAR THIS....'55-'86 cylinder heads will fit on this block, but if you use the L31 heads and plan to use a carb instead of EFI, you will need an aftermarket Vortec intake manifold such as an Edelbrock #7116 Performer RPM intake.
Big block pil pump on small block Chevy dallam11 Engine 22 03-24-2012 08:36 PM
Long block short block fitted block what do opelitis5 Hotrodding Basics 4 01-10-2010 07:12 PM
Need advise for trade. 408 short block for dart iron eagle block sherman8r Engine 6 12-06-2009 05:37 PM
Lookin for a ************** short block or long block Jarod Lee Introduce Yourself 2 09-24-2009 06:25 PM
small block big block weight difference Jmark Engine 3 02-04-2008 01:21 PM
