best paint gun for my application - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2010, 06:45 PM
well i always wanted to get into painting my own car because id always find mistakes when i took my car to a shop
I have a 30 gallon 1hp compressor 120psi (can upgrade if i have to)
im looking for a paint gun to paint my car. The whole car
Ive been researching but I dont want to make a mistake that i will look back at.
I think i should buy a cheap harbor freight gun for primer
and buy a nice gun for clear/base
I have about 200-400 to spend.
Im a beginner but ill be painting alot and practicing.
heres the gun i was looking at
http://www2.shopping.com/xPO-DeVilbi...GUN-MASTER-KIT
would this be a good choice for clear and base or can someone reccomend a different gun that will perform better
Old 03-20-2010, 08:33 PM
Rag top bird's Avatar
Hot rods are still the king
The air compressor you have will not do the job at hand you will need a compressor that will give you 11 cfm
Im ok with cheap primer guns if they spray even a cheap gun can cause more work if they dont spray even and create ripples and I havent used a Devilbiss since the 90s so I cant say on the gun
Old 03-20-2010, 09:46 PM
guiess its time to upgrade the compressor
i only have 110volt though
Old 03-21-2010, 06:50 AM
also time to upgrade power. look at it as an investment. then you can get a good welder a good da. air file the list never ends
"Basic of Basics" Can I use "rattle can" paint on my car? Centerline Body - Exterior 33 07-08-2011 12:33 PM
More on Orange Peel KarKen Body - Exterior 36 03-22-2009 02:18 PM
Paint Gun stinger12 Body - Exterior 24 06-16-2007 03:00 PM
shooting clear vinvango73 Body - Exterior 3 10-28-2005 11:24 PM
Looking to paint my car with OEM quality finish. Have some Questions Gro Harlem Body - Exterior 12 01-15-2005 06:31 AM
