Best painted metal surface to rubber glue? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-02-2011, 09:07 PM
born in '90, drivin a '51
Last journal entry: Engine is in!!!!!!!!!!
Got my new door seals today and It says to align them, tape them in place then glue them... But it doesnt say what glue to use??? What would you recommend??
Old 05-02-2011, 09:36 PM
Joe G's Avatar
3M Super Weatherstrip Adhesive
Old 05-02-2011, 09:41 PM
Thanks! i do have a few questions on that, it says black on the tube? what other colors are there and whats the best one to use? also where can i get it and how much will i need to do two doors?
Old 05-03-2011, 12:39 AM
Did you post this in the auto body forum as well?
Old 05-03-2011, 12:58 AM
JeffB's Avatar
Use only the black,I recently used the yellow and several months later it fell off ,the black I used in another area is still holding.I would get 2 tubes as the directions tell you to apply to both surfaces and let it set up then press it together.
Old 05-03-2011, 12:41 PM
I didnt post it there... hadnt thought of it that way but good point! and good to know thanks alot!
What's the best GLUE for rubber on running boards? TexasSpeed Body - Exterior 19 01-25-2016 12:39 PM
Metal to Metal bonding glue Jerry Hamlin General Rodding Tech 21 11-25-2007 06:48 AM
Glue for running board rubber cboy Body - Exterior 13 02-05-2006 05:50 PM
Bare metal frame needs Painted... EASTWOOD? bg Body - Exterior 8 03-28-2005 08:27 PM
control arm bushings: poly/rubber or metal. bullheimer Suspension - Brakes - Steering 10 03-26-2005 07:59 PM
