best penetrating lubricant - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2008, 04:57 PM
72 grabber 51F-1 65 chevystang
What would you say is the best. I have used Wd40 and it was pretty good, the super tech stuff sucked. I bought a can of PB Blaster and it woked great. I have heard of Kroil but never seen it in a store
Old 10-21-2008, 05:20 PM
Wiki Edits: 31
PB Blaster is the best.. all of the shops I'v been to, use only PB Blaster also.. so it's not just me
Old 10-21-2008, 05:29 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
PB blaster is the best I have ever used. If there is something better I would like to know about it.
Old 10-21-2008, 05:32 PM
kc0kfg's Avatar
kc0kfg
PB Blaster
PB Blaster .... Nothing better Nothing more to say.
Brian kc0kfg
Old 10-21-2008, 05:39 PM
71 c-10's Avatar
just a kid and his truck
pb blaster is by far the best that is easily obtainable. kroil is definitely the best if you can get a hold of it. it will actually creep up a bolt and into the threads and loosen the most seized bolts. our guys use it for water main and water meter replacements to get bolts off that have lived 10 feet under ground for 50 years. We get it at the water authority here in VA and we had it at my old shop, both places i know we have to special order it, and it is crazy expensive, so im glad i don't pay for it. we also have this stuff open and shut made by Drummond America that works really good, but as well as kroil it is hard to get with out a rep. if any one is interested in these two PM me and i'll see if i can get samples or at least some contact info. Also i have seen the kroil at fishers hard ware in Springfield VA, maybe a place like them or ace hardware in your local area would have it
Old 10-21-2008, 07:20 PM
Cape Cod Bob's Avatar
Used to get ZEP 45 .but haven't seen it in a looong time
Old 10-21-2008, 07:26 PM
302 Z28's Avatar
Never heard of PB Blaster, but I have never had a reason to switch from CRC.
Vince
Old 10-21-2008, 08:35 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
Kroil works very good. Seafoam does too, check out NAPA.
If your looking to loosen rusted nuts and bolts, apply heat and paraffin wax (candle) to wick up the threads. Most loosening agents have paraffin wax in their formula.
Old 10-21-2008, 09:17 PM
grouch's Avatar
Last wiki edit: How to document your project
Last journal entry: 1949 Olds -- Rotisserie, pt. 9
Wiki Edits: 2
PB Blaster stinks but works. The can looks like it's straight off a late-night tv infomercial -- but it works.
Old 10-21-2008, 09:38 PM
IDK why but I like the can. it gives me something to look at
Old 10-21-2008, 09:48 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
two products used by a big fleet I used to work for:
Howes:
http://www.howeslube.com/products/index.php/category/40
and... NUTS OFF I saved an empty can just for grins. I think it was a bright yellow can with huge red letters outlined in black. It really got your attention
yep, I found a pic on hamb
Old 10-22-2008, 12:04 AM
327NUT's Avatar
WWW.Roadster.com has "Gibbs Brand", I've never used it but they swear by it, might want to look it up...
Old 10-22-2008, 12:56 AM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
I have never heard of PB Blaster either.
I have tried different products over the years, and nothing but, K&W Products, Knocker Loose Penetrating Fluid has worked as well. All of the other brands I have tried have been a disappointment, to say the least.
I use it as a lubricant, when drilling and tapping, along with 'rusted' exhaust bolts and nuts. It also use to' claim' it will free up 'stuck piston rings' on the can. Believe me it still works! I just did this 5 months ago, in a Honda that sat for a year with a blown head gasket, with coolant in the cylinders.
Old 10-22-2008, 10:04 AM
PB blaster is by far the best! As Grouch said it stinks (That's an understatement!) but it works. CRC and Kroil are both good too but the PB has them beat IMO if you can stand the smell, something that smells that bad just has to work!
Old 10-22-2008, 10:13 AM
kc0kfg's Avatar
kc0kfg
PB Blaster stinks
PB Blaster stinks but works. .
I must admit the smell don't bother me But the wife can always tell when I have been using it, and trust me I really heard about it the last time i used it in the house for something.
Brian kc0kfg
1941 Chevy transmission and rear end lubricant. CrashFarmer2 Transmission - Rearend 2 06-30-2008 06:17 AM
Vega Steering Box Lubricant Ted's37 Suspension - Brakes - Steering 2 11-25-2007 06:30 PM
1931 Chevy Steering box lubricant PA-Farmer Suspension - Brakes - Steering 4 11-10-2006 06:38 PM
waste oil lubricant cboy Garage - Tools 2 11-27-2004 07:10 PM
Which Penetrating Oil? 98rocket General Rodding Tech 8 04-05-2003 03:07 PM
