Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - best performance upgrades for '72 402
Old 09-20-2011, 12:59 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
Due to the lower cube displacement, the 396 and 402 have really been pushed to the side. Most advice you`ll get is "Get a 454" And that would be my advice as well as it`ll cost the same to build the 454 as it will the 402, only the 454 is over 50 cubes larger. I`d sell the 402 and use it towards a 454. Or, if you could just get a 454 block and slap your crank in it, you`ll have a 427 which are hard running big blocks as well.
