-   -   best performance upgrades for '72 402 (http://www.hotrodders.com/forum/best-performance-upgrades-72-402-a-205822.html)
ldm3rd 09-20-2011 12:43 PM
Can someone tell me what are the best performance upgrades for a 1972 402? I am starting with a "I suppose a stock' 402 and I have never built one of these before. Should I change the crank for more displacement or just work on the top-end? Any help and advice would be great. Thanks
DoubleVision 09-20-2011 12:59 PM
Due to the lower cube displacement, the 396 and 402 have really been pushed to the side. Most advice you`ll get is "Get a 454" And that would be my advice as well as it`ll cost the same to build the 454 as it will the 402, only the 454 is over 50 cubes larger. I`d sell the 402 and use it towards a 454. Or, if you could just get a 454 block and slap your crank in it, you`ll have a 427 which are hard running big blocks as well.
techinspector1 09-20-2011 03:19 PM
^^^times two :thumbup:
ldm3rd 09-21-2011 09:50 PM
Thanks for the advice...I will look into the 427 idea. Thanks again. ;)
