Best place to install electric fuel pump? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-30-2010, 04:12 PM
Will the edelbrock fuel pump 1791 work well installed by the engine rather than the fuel tank?
Old 12-30-2010, 04:17 PM
WDCreech's Avatar
Grumpy Old Goat Herder
Electric pumps push better than they pull, so the best place for one would be slightly lower than the tank outlet, but close.
airboat's Avatar
Best place is behind fuel tank and lower. Can't always have best... Will it work... Sure...Could it cause problems, Sure...
Old 12-30-2010, 07:53 PM
nastynova's Avatar
^^this... improper placement leads to premature failures...
Old 12-30-2010, 10:01 PM
WDCreech's Avatar
How so? It's best to gravity feed the pump, and for drag racing it's best to have the pump behind the tank/cell.
Old 12-30-2010, 10:04 PM
nastynova's Avatar
I was trying to simply state that your quote it correct... and the other placements in incorrect places can lead to problems... that all...
Old 12-30-2010, 11:12 PM
Ok understood. thanks
Old 12-31-2010, 05:28 PM
Lower than the fuel tank and as close to it as possible.
Old 09-19-2012, 09:09 PM
keitho64's Avatar
Last journal entry: 1969 Porsche 911 ( IROC Clone)
OK so I am going to resurrect an old thread. My 1969 911 has an electric fuel pump mounted in the engine compartment. It is feeding a pair of weber carbs so I am running the fuel pressure at 4psi and it is controlled by an adjustable regulator. This was the factory installation so it has been this way for a long time, it is pulling the fuel through rather than pushing.
I am running into a situation where the fuel pressure will intermittently drop to 1.5 to 2 psi. When this happens my wide band o2 sensor will show AFR greater than 15.6.
I am going to relocate the fuel pump and mount it at the base of the tank and push the fuel through vs pull, which is how it is operating now. I am not sure if my pump is failing, if it is sucking air or vapor locking.
After reading this thread and a few others the general consensus is electric pumps operate better when pushing. I know my car came from the factory with the electric pump pulling but the modern fuel blends may be playing a part in the problem.
OK so now the real question, should I add a return line for the tank while I am at it? Is a return line needed on a carb setup? I assume not since it never had one but best to check first.
Thanks
Keith
Old 09-20-2012, 08:38 PM
Cape Cod Bob's Avatar
After reading lotsa info on this when I put in my electric pump , the consecus was that a 7=8 lb pump running to a 4 lb reg will be OK without the return line. I used a napa pump .
How old is your pump? I was told by an napa old timer that they don't last to long. Maybe you just need a new one.
Electric Fuel Pump Install??? riesman20 Engine 19 12-29-2012 08:01 AM
Should I install an electric fuel pump 29guy Engine 3 12-25-2007 08:46 AM
fuel filter (Best Place) to install 39chevy Engine 3 07-31-2006 08:05 AM
electric fuel pump install question bet on black Engine 5 02-01-2005 05:32 PM
Electric Fuel Pump Install?? riesman20 Electrical 9 05-25-2004 08:54 PM
