Best place to put a water temp gauge sensor? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2009, 01:24 PM
Where is the best place to measure water temp in a Gen 1 small block chevy?? The water is probably the hottest as it exits the block through the thermostat located in the intake manifold, so that should be the best place to measure water temp at right?
Old 05-11-2009, 02:48 PM
the intake works just fine, so does the port in the cylinder head near the exhaust manifold. I have used both with good results.
Old 05-11-2009, 06:20 PM
fast68's Avatar
likes chevy trucks & boobies
technically hottest would be closest to cylinder water jackets because this is where the combustion takes place.
but it doesnt really matter where and GM has used a cylinder head(69-up), and the intake(55-68) over the years on the SBC and 90 degree v-6 engines.
good luck
Old 05-12-2009, 05:07 AM
I have the stock sensor in the driver's side head, and have tried my mechanical gauge in both the passenger side head and in the intake manifold (where it is now).
Many folks assume the temp measured at the head will be hotter (makes sense), but in my engine there was very little difference - maybe five degrees hotter than the sensor in the intake.
Bruce
Old 05-12-2009, 08:10 AM
302 Z28's Avatar
I have tried both places also, in the intake and the side of the head. I also noticed only about a 5 degree differential, but in the head the gage showed a quicker temp rise.
Vince
Old 05-12-2009, 06:17 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
I like to put it in the manifold near the thermostat so I can monitor how and when the stat is opening.
Temp sensor location longt Engine 6 07-31-2007 02:17 PM
Aftermarket temp sensor location? Steves66 Engine 5 09-20-2006 06:18 PM
Water temp sensor location for fan switch subman17 Engine 4 11-10-2004 12:47 PM
Temp gauge grandprix601 Electrical 2 03-17-2004 08:45 AM
Water temp varies?? Mudstomper Engine 5 03-12-2003 04:18 PM
