Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Best Place for Temp Sensor for Electric Fan?
Old 09-18-2011, 09:09 PM
trifivefan trifivefan is offline
Thanks, guys for all the great advice. If I use a sensor on one of the cylinder heads, what temp sensor should I get? If this setup will indicate hotter, should I go with a 190 degree? With the sensor on the lower hose, like Ogre suggested, would the temp sensor be of a lower rate, say 180 degrees?
