best power source for electric choke? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-17-2012, 04:50 PM
Guys,
I'm installing an electric choke on my 69 mustang and need an ignition activated positive to attach to. where is the easiest one to piggyback on?
Mike
Old 07-17-2012, 05:04 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Probably the cigarette lighter if it's only hot key-on, easy to locate. Next seems like the radio feed, not the clock lead, that's hot full time. You can't find an empty slot in the fuse panel to tap into? You have a probe tester, one end clips to ground the other probes wires?
Semper Fi
Old 07-17-2012, 05:12 PM
Richiehd's Avatar
JS-70
We used to run a hot lead from the field side of the alternater, this way the choke was not energized with the key in the ACC position.
Old 07-17-2012, 06:30 PM
Some newer choke instructions tell you not to use the alternator field for power, but I'm not sure why. A good key-on power source on GM cars is the wiper motor, but I'm not sure if that's easy to reach on a Mustang.
Bruce
Old 07-18-2012, 06:06 AM
I use the power going to my distributor. If you use a coil with a resistor then get the power before the resistor.
carburetor, electric choke
changing a divorced choke to a electric choke? Help please?e 71GMC Engine 1 02-11-2012 06:14 PM
70 Impala where to hook up electric choke and tach 12v ignition fuse source? jarhead_615 Electrical 0 05-10-2010 10:03 PM
electric choke gcanavy Electrical 2 01-23-2009 01:01 AM
take off electric choke elcaminodragster Engine 14 07-18-2007 08:09 AM
Electric choke 3100 Special Engine 10 04-23-2006 09:46 PM
