Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - best primer and sealers to use
  #16 (permalink)
Old 07-05-2012, 06:44 AM
gnmnj gnmnj is offline
Originally Posted by BarryK View Post
Deuce hit it on the money use only an epoxy primer over the bare
Unless your using lacquer or enamel as your color coat
you should not use an acid etch primer.
When you get it stripped to bare metal email me off line and I will
send you "The Perfect Paint job" It gives step by step from bare metal up. It was written for Restorations and Street rod builders only not everyday paint It does apply to any paint brand.
Could I please get a copy of "The Perfect Paint job" I am going to try my luck on a 1957 cheverolet. Need all the help I can get
