Best product to bond light Boxes to Fiberglass Fenders? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2011, 01:05 PM
35WINDOW's Avatar
Last journal entry: Engine!
I had some flush mounted lenses made for my Car by Lambert Enterprises, and I have to bond fiberglass boxes t the backside of my Wescott rear Fenders. The Boxes do attach at a 90 degree angle to the Fender-
What Product would you use for this? Vette Panel bond/adhesive? Kitty Hair? I was hoping that I wouldn't have to break out the Fiberglass/Mat-how about Lord Fusor #148/148?
Old 07-27-2011, 01:34 PM
35WINDOW's Avatar
Here's a few pictures of the new lenses-
ID:	57126   Click image for larger version
ID:	57127   Click image for larger version
ID:	57128   Click image for larger version
ID:	57129   Click image for larger version
Old 07-27-2011, 01:47 PM
shine's Avatar
Last journal entry: some progress
i believe i would use atv silicone adhesive . you may need to remove or replace later. unless there is more to it than the pics .
Old 07-27-2011, 01:58 PM
35WINDOW's Avatar
Shine,
I was hoping that you would chime in here-I have already cut the holes and bonded the lenses to the Fenders (using Lord Fusor plastic bonding adhesive)-Lambert sent some fiberglass boxes (that I'm sorry to say that I don't have pictures of) that I have to bond to the fenders-what I didn't mention is that the LED's are mounted to aluminum that is screwed to the back of the Boxes and then siliconed to seal (and for servicing the LED's), so I think I may want to mount these a little more permenently-
Old 07-27-2011, 02:02 PM
shine's Avatar
as long as you have access it would be fine to use fusor or vette panel adhesive. kinda figured there was more to it.
Old 07-27-2011, 02:04 PM
35WINDOW's Avatar
Last week I ordered some Vette Panel Adhesive (as per some of your Posts), but just didn't know if it was strong enough to hold the Boxes, so I read Evercoat's product sheet and got scared-sounds like it will, so thanks!
Bond Fiberglass to Metal Richard T Body - Exterior 1 05-31-2009 02:58 PM
custom fiberglass sub and rack boxes wolfpacs Interior 2 10-10-2006 06:57 PM
What is everyone using to bond fiberglass to metal? beemdubya Body - Exterior 2 12-11-2004 08:46 PM
Fiberglass fenders DJM Body - Exterior 1 08-17-2003 01:11 PM
Fiberglass Fenders christopher406 Body - Exterior 1 10-01-2002 08:36 PM
