best rear end for my s10 project?
i have a 1984 s10 reg. cab longbed 2.8l 4speed and im putting a mild built 400sb bolted to a built th350 into it and im try to find out what would be the best but easiest rear end to use. i would like to find one that is already posi and bolt up and very little modification to fit. your help will be greatly appreciated.
rear end
yea the easiest way i think is find a pull out of s-10 extreme it is a 8.5 ring gear with posi and i think it will be a direct bolt in. or you could do like i did and build a 12bolt with moser stuff,had the axles cut to fit factory width,it cost 2000 and he did all the work.
But maybe the easiest...
Yes your right,But not stronger then a 9'',that's why I said what I said..
thank you all for your help. is there anyway to make s10 rims fit on the ford 8.8
| 4x4 12 bolt rear end same as 2wd rear end??? | Ed ke6bnl | Transmission - Rearend | 2 | 05-24-2008 02:25 PM |
| will a '69 Chevelle rear end fit into a '70 Chevelle? | SMO'KUM UP | Introduce Yourself | 2 | 09-17-2007 07:15 AM |
| Narrowing a 9" ford rear end | powerrodsmike | Suspension - Brakes - Steering | 6 | 05-05-2007 12:53 PM |
| Rear end identification help | 71gtx | Transmission - Rearend | 1 | 11-07-2003 07:14 PM |
| anyone running 700r4 with 3.55or 3.77 rear end? | 37 chevy | Transmission - Rearend | 7 | 01-06-2003 06:34 AM |
