best rear end for my setup - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-19-2007, 11:03 AM
i have a 350 SB it has a .525 lifter cam. 1 5/8" headers with 2.5" exhaust. its a th350 3 speed tranny built and has a shift kit. and it has a 308 rear end. wat would be the best rear end for what i have?
Old 10-19-2007, 09:18 PM
ok, what type of vehicle is this set-up in? What will it's uses be, i.e. street, strip, towing. Also, what type of housing, you said a 3.08 gear but is it a 10 bolt, or 12-bolt.
Old 10-19-2007, 09:24 PM
2NDChance's Avatar
Newbie-but learning
ratio stuf
what size tire - i have 400 small w t350 3.42 rear 235 60 r15- at 55 mph rpm is about 2800, 3200 at 65
Old 10-20-2007, 09:21 AM
the rear are 275 50R-15
Old 10-20-2007, 09:23 AM
Javelin69
its in a 81 camaro for street use and its a 10 bolt
Old 10-20-2007, 11:00 AM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
According to this Tire Size Calculator , those two tire sizes are fairly comparable ...
The 275/50's are 25.82" dia (81.11" circumference)
The 235/60's are 26.10 dia (81.99" circumference)
Summit racing has a chart and formula that will give you some insight as to what to expect as well.
If this car is going to see ONLY or at least a MAJORITY of street use ... then lower gears might be fun ... but if it's going to see the highway at all, youll want to see either and OD trans or lower ratios, IMHO.
I'm thinking that anything over ~3000 -3200 RPM sustained can't be good. That translates to 3.90 to 4.10 ratio in your case.
2nd Chance ...
According to that chart and your tire size ... I'd get that speedo checked. I have a hunch that you're going faster than you think at that RPM.
Old 10-20-2007, 11:07 AM
66gmc
so wat do u think about like 3:56 gear? would tht be ok for highway speeds but if i wanted to take it to the drag itd be ok too?
Old 10-20-2007, 11:16 AM
66GMC's Avatar
Yeah ... I think the 3:56's would be a "reasonable" choice.
2800 cruise rpm should be ok for about a 1 or 2-hr highway jaunt ... and switching to a "built" OD trans later would be an option.
I had a '68 Torino C6 trans, G60-14's, 3.50 gears ... which put the cruise RPM in about that 3200 range. I drove it 60 miles from home to the track ... with no apparent effect.
A buddy had a camaro with 4:10's and 15" tires ... he also ran about the same cruise RPM as I did on the same trip.
Old 10-20-2007, 01:21 PM
o ok thank you
Rear end ID ctown Transmission - Rearend 1 05-15-2006 10:20 AM
Rear End Swap to a Wider setup? sifua Transmission - Rearend 3 02-07-2006 05:01 AM
Chevy rear end swap Truplayainfla Introduce Yourself 1 10-23-2004 11:07 PM
1975 8.5 rear end camino_man Transmission - Rearend 6 09-18-2004 05:32 AM
Important rear end mounting question 71gtx Transmission - Rearend 2 01-04-2004 06:05 PM
