Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - best reciprocating saw blades?
Old 05-18-2011, 03:51 AM
HVAC Phil HVAC Phil is offline
If you are cutting metal, thick metal, Milwaukee makes a blade called "the torch". This blade will cut and cut. I use it to cut thru old cast iron boiler pipes. Cuts like butter. They aren't cheap, but save a bunch of time. They last pretty good too.
