Best route for transmission swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2008, 02:53 PM
70 Chevelle SS 396
I've been looking into a 5 speed swap for my '79 Triumph Spitfire. There are overdrive units, and 5 speed conversion kits; But, the overdrive units are either pricey or hard to come by. I'm trying to "engineer" my own conversion rather than spend the big money on a pre-made kit (what's the fun in that, anyways? )
I think it would be best to use the Spitfire bell housing and machine an adapter to fit it to the gearbox of choice. My dilemma is how to mate the clutch and trans.
So, my question is: Would I be better off-
A. Trying to find a transmission with the same type input shaft to fit the Spitfire clutch (0.875 x 20 spline, but I've only found FWD transmissions with the same clutch spline size)
B. Mating a clutch from the donor trans to the Spitfire flywheel (which would clear the bell housing)
or C. Mating the spitfire clutch to the donor trans, by means of some kind of splined adapter, or by grafting the Spitfire input shaft to the input shaft of the donor gearbox?
I hope I made some kind of sense. Any suggestions?
Nooj
Old 02-19-2008, 09:25 PM
Transmission
Hi, I don't know if it will fit, not much on the british cars, but my friend has a good 5 speed out of a Triumph TR-7, I put a Ford 302 and automatic in the car for him, but he only wants 500.00 for it if it will work, might be an easy way put. Keith
Old 02-21-2008, 05:35 PM
70 Chevelle SS 396
Anyone know about the TR7 5 speed transmissions?
Maybe a complete engine and 5 speed setup from a TR7 would be a fairly simple swap into the Spit. Would probably require no more special work than fitting an odd gearbox to the Spitfire engine. The TR7 engine is a little bigger (but not too much- maybe 4-500 cc's).
Any Triumph people out there?
Nooj
Old 09-10-2014, 01:19 PM
Nooj
I do believe that the tr7 5 speed trans is longer and taller so things like driveshaft and mounting locations as well as the tunnel modifications will need to be changed. As for the bellhousing I believe it will have the starter mount on the passenger side so an adapter to the spitfire bell housing would be a good idea.
Old 09-10-2014, 02:11 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Ok guys the old school way was to use the pressure plate that came with the car and use the clutch disk with the spline count to fit the trans.. Some sort of adapter is used to bolt the trans to he existing bell housing. Of course there is some perusal of parts catalogs to figure out the right parts of course..
Sam
Old 09-10-2014, 06:08 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Old thread. The OP has not logged in since 2012 , may be no response.
C4 tailshaft swap? 70chevyc10 Transmission - Rearend 1 07-06-2007 06:49 PM
Cam swap Questions wayfast77 Engine 3 10-18-2006 04:52 AM
Street Legal TV to Broadcast Video from NMCA Super Bowl Event at Route 66 nmrajames Hotrodders' Lounge 0 07-26-2006 09:53 PM
Route 66 Swap Meet, Joplin Missouri Chrislj10 Hotrodders' Lounge 0 01-31-2004 06:08 AM
