Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Best rust converters for surface rust
Old 10-29-2011, 10:06 AM
John68040's Avatar
John68040 John68040 is offline
Originally Posted by deadbodyman
for the bottom of a floor pan you should use a rubberized undercoating on top.
That's what I want to do. Remove rust, primer+epoxy, then undercoating over that. Can either Ospho or naval jelly be used easily enough while the car is on a lift and I'm standing under it?
