Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Best rust converters for surface rust
  #39 (permalink)
Old 10-03-2012, 06:54 AM
Lizer Lizer is offline
Originally Posted by TARM View Post
Is there some reason you can not just use a 0-14 PH testing strip on the metal surface after all the steps DBM does prior to spraying primer and see what you get?
Yes; pH strips require full immersion in the solution for which you are testing the pH and they need to be completely wet. Touching it to the metal would not give you a good reading.
Seems like a really simple and 100% way to put this to bed. I can not see how there could be any argument if the PH comes back somewhere around in the middle of the PH range. A 85% Phosphoric acid solution has a PH of about 0.5 PH so we are not talking some small change here.
You're only looking at pH and not chemical compatibility.
Wiping off clean with a rag soaked in wax & grease remover (I think this may have a big effect)
You would have to clean the metal with wax and grease remover anyways. But it's nothing I count on to neutralize an acid.
