-   -   Best rust converters for surface rust (http://www.hotrodders.com/forum/best-rust-converters-surface-rust-207763.html)
John68040 10-27-2011 05:02 PM
So I've been looking up rust converters and have read mixed reviews on here and elsewhere on most of them. Some people swear by POR15, others say to stay well away from it. My dad used the Rustolem Rust Reformer on his Bus and it appears to work quite well but seems a little too hard - like it might crack. Then there's the Eastwood ones I've heard mostly positive reviews on. Which ones work? What about the spray chemicals that are supposed to remove rust?
I want to do the floorpans and some hard to reach areas of my car then undercoat it. The whole floor is light surface rust. I want to stop it and keep it from turning into rot. Are there any better options? Media blasting?
deadbodyman 10-27-2011 06:06 PM
This is what I've used for years. http://www.hotrodders.com/forum/osph...Ospho+solution
Heres another good one...
http://www.hotrodders.com/forum/secr...Ospho+solution
both are inexpensive (under 20.00) and remove rust but need to be scrubbed in not painted on There many phosphric acid products out there but Ospho is what works best for me. It aint as easy as painting something on but it works a whole lot better.
use an epoxy primer over it...
mitmaks 10-27-2011 10:11 PM
I had used both POR15 and Rust Mort with good results.
deadbodyman 10-28-2011 06:31 AM
did you use Por -15 on the outside of the car ???? or just floors etc....
John68040 10-28-2011 08:53 PM
I forgot about the Naval Jelly, that really seems like the best option - at least for areas I can reach. The only thing is I've only seen people posting about using it on fenders, hoods, roofs, etc. Anyone have experience using it on a floorpan standing under the car? Does it drip, run off, etc?
mitmaks 10-28-2011 09:27 PM
Trunk floor, in behind 1/4 panel/sail panel areas. Trunk floor is still looking great after 7 or 8 years.
50bowTie 10-28-2011 10:30 PM
Originally Posted by John68040
So I've been looking up rust converters and have read mixed reviews....
....The whole floor is light surface rust. I want to stop it and keep it from turning into rot. Are there any better options? Media blasting?
They do convert the rust to "something".
You CAN paint this "something".
But there is a good chance that someday sooner or later that acid will creep through your paint and do nasty things. Why risk it? If you can abrade the metal until it's shinny clean, and cut out the cancer spots/weld in patches,...
An Epoxy will last many more years than any "Rust Converter" could ever dream of.
mitmaks 10-28-2011 10:33 PM
These rust converters DO work, however pretty much every one strongly recommends to be topcoated. An epoxy primer would be perfect to put over rust converter.
deadbodyman 10-29-2011 04:58 AM
Ospho and Navel jelly have a few advantages over paint on converters,they actually REMOVE rust and convert any small traces left behind to iron oxide.
A few advantages Ospho has over navel jelly is its much stronger ,faster and does not need to be neautralized with water...I've personally never had a paint problem with it in 35 yrs and hundreds of cars.But then again I've seen people screw up using W&G remover so its not fool proof...
My personal opinion is ,if there's rust I wont prime if its not scrubbed down with Ospho first (its the law) even if a car is sandblasted it gets Ospho right away to protect the bare metal from surface rust
You can put it in a pump bottle and spray it on it can also be used as a converter and simply spray it on and paint when its dry...I dont use it this way but The guys that paint rusted metal roofing swear by it.
so if your looking for an ez spray on half measure fix you might as well save a bunch of money too Ospho only costs 15,00 a qt but for the bottom of a floor pan you should use a rubberized undercoating on top.
Lizer 10-29-2011 08:47 AM
How many people have actually sanded the converted rust spots that now appear black? Can't speak for Ospho, never used it, but other rust converters I've tried, whether it be other naval jelly or even zinc phosphate turn what rust spots that aren't dissolved black. If you go sand those black spots after they've been 'converted,' you hit more orange rust underneath. That just doesn't sit right with me so I mechanically remove all the rust first if it's just surface rust. Then I'll put epoxy over it.
Also, I'm just a hobbyist, not a pro.
John68040 10-29-2011 11:06 AM
That's what I want to do. Remove rust, primer+epoxy, then undercoating over that. Can either Ospho or naval jelly be used easily enough while the car is on a lift and I'm standing under it?
rsfyj 10-29-2011 11:33 AM
Rust under the black
Don't get shook up about it, rust can keep rusting with out water and oxegen thats what the black converted acid does it converts it and seals it. if you sand it off you have opened the wound again let it be and drive and be happy. Do not try to cross bridges until you have to cross it. I have never had a problem with the stuff i use shelf life is only good for 7 or 8 months I buy a pint at a time. It says on the directions do not sand or grind after you apply the stuff. Its only a Car fellas.
deadbodyman 10-30-2011 07:38 AM
EXACTLY!!!!!!! give that man a cigar.....
strip off the paint ,sand with 80,get out the wire wheels and ospho and get that rust out of there...do it again if you need too...then start prepping for epoxy....it IS a lot of work and it dirty... but sometimes media blasting just isnt a feasible way to go
deadbodyman 10-30-2011 07:54 AM
Sure, its like the other member said its only a car and how much time and money you want to spend on a repair is totally up to you. To start with you have to remove all the undercoating and find ALL the rust or you can,OR you can just hit the spots you see with a wire wheel and convert them.It all depends on how nice you want it ,how long you want it to last and how much time your willing to put into it...
Hey,theres even a guy in town that painted the bottom of his floor to look like diamond plate,it was impressive but not very practical or cheap...
shine 10-30-2011 08:42 AM
there is no such thing as "converting " rust. you can use various chemicals to turn it black or purple even pink but it is still rust living in the metal . you can cover it up with any of the wonder snake oils but it is just covered. sooner or later all that will be left is the snake oil because the metal will still rust. one pin hole all the way through and you have a snug warm rust hotel .
if it was that wonderful you would see high end restoration shops swearing about it instead of swearing at it . your car, your choice .
