This is what I've used for years. The Ospho Solution..(rust removal)
Heres another good one... secrets of surface rust removal revealed both are inexpensive (under 20.00) and remove rust but need to be scrubbed in not painted on There many phosphric acid products out there but Ospho is what works best for me. It aint as easy as painting something on but it works a whole lot better. use an epoxy primer over it... Last edited by deadbodyman; 10-27-2011 at 05:22 PM. |
I had used both POR15 and Rust Mort with good results.
did you use Por -15 on the outside of the car ???? or just floors etc....
I forgot about the Naval Jelly, that really seems like the best option - at least for areas I can reach. The only thing is I've only seen people posting about using it on fenders, hoods, roofs, etc. Anyone have experience using it on a floorpan standing under the car? Does it drip, run off, etc?
They do convert the rust to "something". You CAN paint this "something". But there is a good chance that someday sooner or later that acid will creep through your paint and do nasty things. Why risk it? If you can abrade the metal until it's shinny clean, and cut out the cancer spots/weld in patches,... An Epoxy will last many more years than any "Rust Converter" could ever dream of. |
These rust converters DO work, however pretty much every one strongly recommends to be topcoated. An epoxy primer would be perfect to put over rust converter.
Ospho and Navel jelly have a few advantages over paint on converters,they actually REMOVE rust and convert any small traces left behind to iron oxide.
A few advantages Ospho has over navel jelly is its much stronger ,faster and does not need to be neautralized with water...I've personally never had a paint problem with it in 35 yrs and hundreds of cars.But then again I've seen people screw up using W&G remover so its not fool proof... My personal opinion is ,if there's rust I wont prime if its not scrubbed down with Ospho first (its the law) even if a car is sandblasted it gets Ospho right away to protect the bare metal from surface rust You can put it in a pump bottle and spray it on it can also be used as a converter and simply spray it on and paint when its dry...I dont use it this way but The guys that paint rusted metal roofing swear by it. so if your looking for an ez spray on half measure fix you might as well save a bunch of money too Ospho only costs 15,00 a qt but for the bottom of a floor pan you should use a rubberized undercoating on top. |
How many people have actually sanded the converted rust spots that now appear black? Can't speak for Ospho, never used it, but other rust converters I've tried, whether it be other naval jelly or even zinc phosphate turn what rust spots that aren't dissolved black. If you go sand those black spots after they've been 'converted,' you hit more orange rust underneath. That just doesn't sit right with me so I mechanically remove all the rust first if it's just surface rust. Then I'll put epoxy over it.
Also, I'm just a hobbyist, not a pro. |
Rust under the black
Don't get shook up about it, rust can keep rusting with out water and oxegen thats what the black converted acid does it converts it and seals it. if you sand it off you have opened the wound again let it be and drive and be happy. Do not try to cross bridges until you have to cross it. I have never had a problem with the stuff i use shelf life is only good for 7 or 8 months I buy a pint at a time. It says on the directions do not sand or grind after you apply the stuff. Its only a Car fellas.
strip off the paint ,sand with 80,get out the wire wheels and ospho and get that rust out of there...do it again if you need too...then start prepping for epoxy....it IS a lot of work and it dirty... but sometimes media blasting just isnt a feasible way to go |
Hey,theres even a guy in town that painted the bottom of his floor to look like diamond plate,it was impressive but not very practical or cheap... Last edited by deadbodyman; 10-30-2011 at 07:03 AM. |
there is no such thing as "converting " rust. you can use various chemicals to turn it black or purple even pink but it is still rust living in the metal . you can cover it up with any of the wonder snake oils but it is just covered. sooner or later all that will be left is the snake oil because the metal will still rust. one pin hole all the way through and you have a snug warm rust hotel .
if it was that wonderful you would see high end restoration shops swearing about it instead of swearing at it . your car, your choice . |
| Currently Active Users Viewing This Thread: 3 (0 members and 3 guests) | |
| surface rust | deepsea29c | Body - Exterior | 4 | 03-10-2007 01:58 PM |
| Surface rust | 57halfton | Body - Exterior | 2 | 07-29-2006 04:00 PM |
| surface Rust? | kevex | Body - Exterior | 4 | 02-19-2006 02:32 AM |
| surface rust | mercury88 | Body - Exterior | 1 | 08-03-2005 10:45 PM |
| Surface Rust | Benji | Body - Exterior | 7 | 02-25-2003 06:36 AM |
