Chevy,
EngineQuest Vortec 180 cc www.shaverengines.com
AFR is a good aftermarket aluminum that is relatively problem free.
Edelbrock seems to have lots of problems "out of the box".
Chevy,
On the internet you'll hear about AFR by a lot of people with anecdotal evidence. I would never buy from a company that fakes dyno sheets, mis represents, no wait RIGS TESTS, published tests in magazines and on the internet, and uses Chinese castings.
They are a perfectly good head, however, my disgust with them transcends the fact they are a good product. Mostly it's their customer base which consists of 85% leg humping know nothings that can only spout what is printed in the AFR brochure and means relatively nothing in real life, combined with their claims of vast superiority which I find unproven. AFR has the best marketing machine in the industry and owns the internet market.
If power and speed is your thing, Brodix, All Pro, and Dart are the leaders. AFRs are just CHEAP. If you get into the fully CNC'd market, they aren't even cheap anymore.
Brodix, Dart, Edlebrock, All Pro all own their own foundries in the US and do their own castings. Fact of the matter is, depending on your combination, all those heads will perform slightly better or worse than the next, but there's not a world of difference between them. You're talking 25 HP head to head, sometimes one will be on top, sometimes the other.
Sorry Scot, this wasn't toward you, just a frustration I've dealt with for the past 18 months.
None, that's what AFR does to people who compete. Internet rumor.
Ya know, AFR had their own casting problems most pronounced was the oiling issue where some people are convinced they smoked their engines as a result of oil pooling in the heads. Their new castings are better now that they have their new foundry overseas.
my engine setup is a 377 (400 block with 350 crank) a 280HR retrofit cam, kb pistons, eagle H beam rods, edelbrock performer rpm intake. i was looking to get about 450 hp and ft lbs outta it in the lower rpm range. seems like roller cams dont rev as high anyway. i have around $1300 to spend on heads. and i need them to last.
If that were my budget, I'd look at the Brodix IKs. THey are cheap, under $1000. You can probably pick them up for $900 locally. There's motors making close to 600HP with the 200s,out of the box as cast. They have great casting materials, many consider Brodix best castings in the business. Anything else is going to over $1300. If you do this, ask for more spring than you need it will be cheap or nothing to upgrade at this juncture.
The only caveat is that they only come in straight plug configurations. You have to make sure you get headers which support straight plugs. That is their Achilles Heel.
Ok lets back up here a minute, "SSmonty" claims he has 2 cc diff. in his combustion chambers and that his valves didn't seat. Then he later justifies the problems as probably HIS ERROR and says he's had them since 2000, CHANGED the valves, ported the bowls (did you ever nick a seat while doing a little bowl work???) then polished the chambers and god only knows what else was done.
Then some of you guys jump on the old band wagon and tell "jak327" that Edelbrock has some "out of the box problems". Is "SSMonty" story the basis for your ridicule of Edelbrock's machine work??....or do you have something else?? I've had 2 sets of their heads on previous engines and a new set of 60899's on my 331" sbc, which is running but not on the street yet, sorry, narry a problem.....like probably thousands of other customers running their heads.
EVERY manufacturer is going to pass a lemon now and then but to blatantly catagorize Edelbrock's quality by this "first hand experience" is absolutely rediculous.
Posted by 327NUT:
"EVERY manufacturer is going to pass a lemon now and then but to blatantly catagorize Edelbrock's quality by this "first hand experience" is absolutely rediculous."
Geez, who put a burr under your saddle?
You asked this: "What type of "out of the box" problems do Edelbrock cyl. heads have?"
Jsup answered this: "None, that's what AFR does to people who compete. Internet rumor."
I remembered the thread by SSMonty, so I posted it because here is a guy with firsthand experience, not an internet rumor. Just trying to show both sides and yes, I agree that there will be a bad run from most any mfg once in a while.
- Usually high quality castings and machining, leads to a minimum of problems. Not to say that you don't get the occasional error, but from them it's fluke not the norm.
- Really good power bands, they understand the need for improved port shape rather than just big ports. This provides a wide RPM band where the the bottom to mid range torque and the top end horsepower blend smoothly without undue trades of one against the other.
- Emissions legal, the company puts out the effort to produce not only an effective product but also one that meets EPA and CARB requirements. This isn't easy to do and certainly isn't inexpensive, but it shows both a commitment to high quality engineering and to the environment. When one considers that the entire hot rod hobby and industry can be wiped out with a stroke of Obama's pen, it's important to support companies that can stand up before a congressional committee while pointing to making effective yet responsible products. This needs to be rewarded by the consumer, as opposed to buying cheap Chinese made knock-offs.
Depends a lot on how big the cam is, the Performer and E-Tec 170 actually out perform the E-Tec 200, Victor and Victor Jr. on the flow bench from .4 inch down. The bigger heads really don't begin to bare their teeth till between .4 and .5 inch and more lift.
Remember what I said about port efficiency, what you want especially for a street engine is the most flow thru the smallest volume port that meets the engine's requirements. OK, I didn't say it that way but that's whats meant by an "efficient port". This really sharpens up the bottom thru mid range response and doesn't abruptly kill the upper end.
Jsup, AFR heads are excellent. The performance is one of best heads I have ever seen. They are truely worth looking at. I'm using it on my 406 sbc. It was worth it. :thumbup:
what is the stock angle on heads? the e-tec 200 are at a 23* angle. i would like to be able to use the edelbrock performer rpm intake i already have. save some money....
GenI & II LT1 are 23*, GenIII LS are 15* (I think)<<
Status
Not open for further replies.
You have insufficient privileges to reply here.
Related Threads
Hot Rod Forum
2.2M posts
175.9K members
Since 2001
