Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Best SBC cam and crank bearings?
Old 10-07-2004, 01:37 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
Clevite makes excellant bearings, as are the GM Morraine bearings, however, it doesn`t matter which brand of bearings you use, if any material gets in the engine they wear, and if they can`t they inbed the object. In most cases in fresh rebuilt engine wear I`ve seen was from lack of cleaning it, hone dust sticks in the bore real good and you have to scrub it hard to get it all out, lack of lube from start up or start up with revs also will make them show premature wear, lack of immediate oil change after cam break in and etc.
